On way we have done this in the past was identify a list of public queries that we wanted to track and to add Uniq ID's to the query GUID's as a comment at the start of the public query. After this was completed we had the DBA's do an audit for a range of time and they could track the exact amount of times that public query was used by tracking the GUID's specified by us.
/*{36d43500-b0a7-44f4-a4f4-3c5c56c514af}*/
<Your query>
We could then correlate the data and identify who was running them query and how often. We have typically done this during Major version upgrades of Maximo as its a great time to clean things up.
You also mentioned updating the queries from the back end. You might want to look into setup a Query Manager tool in your Maximo Instance Link to something you might be interested in.
https://youtu.be/xXx7E5fGzQc?si=XCQXB1d67OcLQXZK
You could also go a step further and have some functionality setup to allow Maximo Admins to set the query owner to MAXADMIN (or whatever you admin user is) to allow the queries to be used in Start Center Result sets if required.
You can easily generate a list of GUIDs in excel
Using Power Query
Go to Data > Get Data > From Other Sources > Blank Query.
In the Power Query Editor, go to Home > Advanced Editor.
Replace the existing code with the following:
let
Source = List.Transform({1..10}, each Text.NewGuid())
in
Source
Click Close & Load to load the list of GUIDs into Excel.
This will generate a list of 10 GUIDs. You can adjust the number in {1..10} to generate more or fewer GUIDs.
