Hi Team,
I recently configured ssl in maximo and after that the Node is not synchronized .
-Then to synchronize the node and troubleshoot the issue i removed all the configurations related to ssl (Reverted back the httpd.conf file ,removed certificates from all keystores and trust stores also removed certificates from key.p12 and CMS keystore).
Then still node is not getting synchronized ,
Here is the log details:
[29/02/24 17:05:11:352 AWST] 00000001 AbstractNodeC E ADMU0006E: Exception creating Deployment Manager connection: com.ibm.websphere.management.exception.ConnectorException: ADMC0016E: The system cannot create a SOAP connector to connect to host XXXX at port 8879.
at com.ibm.websphere.management.AdminClientFactory.createAdminClientPrivileged(AdminClientFactory.java:635)
at com.ibm.websphere.management.AdminClientFactory.access$000(AdminClientFactory.java:127)
at com.ibm.websphere.management.AdminClientFactory$1.run(AdminClientFactory.java:210)
at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:63)
at com.ibm.websphere.management.AdminClientFactory.createAdminClient(AdminClientFactory.java:206)
at com.ibm.ws.management.tools.AbstractNodeConfigUtility.getAdminClient(AbstractNodeConfigUtility.java:204)
at com.ibm.ws.management.tools.NodeSyncUtility.runTool(NodeSyncUtility.java:155)
at com.ibm.ws.management.tools.AdminTool.executeUtility(AdminTool.java:271)
at com.ibm.ws.management.tools.NodeSyncUtility.main(NodeSyncUtility.java:69)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:95)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:508)
at com.ibm.wsspi.bootstrap.WSLauncher.launchMain(WSLauncher.java:234)
at com.ibm.wsspi.bootstrap.WSLauncher.main(WSLauncher.java:101)
at com.ibm.wsspi.bootstrap.WSLauncher.run(WSLauncher.java:82)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:340)
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:981)
at com.ibm.wsspi.bootstrap.WSPreLauncher.launchEclipse(WSPreLauncher.java:413)
at com.ibm.wsspi.bootstrap.WSPreLauncher.main(WSPreLauncher.java:174)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:88)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:57)
at java.lang.reflect.Constructor.newInstance(Constructor.java:437)
at com.ibm.websphere.management.AdminClientFactory.createAdminClientPrivileged(AdminClientFactory.java:457)
... 34 more
Caused by: com.ibm.websphere.management.exception.ConnectorNotAvailableException: [SOAPException: faultCode=SOAP-ENV:Client; msg=Error parsing HTTP status line "\u0015\u0003\u0003\u0000\u0002\u0002": java.util.NoSuchElementException; targetException=java.lang.IllegalArgumentException: Error parsing HTTP status line "\u0015\u0003\u0003\u0000\u0002\u0002": java.util.NoSuchElementException]
at com.ibm.ws.management.connector.soap.SOAPConnectorClient.reconnect(SOAPConnectorClient.java:429)
at com.ibm.ws.management.connector.soap.SOAPConnectorClient.<init>(SOAPConnectorClient.java:228)
... 39 more
Caused by: [SOAPException: faultCode=SOAP-ENV:Client; msg=Error parsing HTTP status line "\u0015\u0003\u0003\u0000\u0002\u0002": java.util.NoSuchElementException; targetException=java.lang.IllegalArgumentException: Error parsing HTTP status line "\u0015\u0003\u0003\u0000\u0002\u0002": java.util.NoSuchElementException]
at org.apache.soap.transport.http.SOAPHTTPConnection.send(SOAPHTTPConnection.java:475)
at org.apache.soap.rpc.Call.WASinvoke(Call.java:510)
at com.ibm.ws.management.connector.soap.SOAPConnectorClient$4.run(SOAPConnectorClient.java:379)
at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:118)
at com.ibm.ws.management.connector.soap.SOAPConnectorClient.reconnect(SOAPConnectorClient.java:372)
... 40 more
Please let me know how to resolve this .TIA .
Thanks and Regards,
Swapna
#Administration------------------------------
Swapna Shimpi
DXC
