Hi Jennifer,
I don't know that you need to create an automation script. My understanding of your end state is to send an email to the userid in the 'Delivered To' field.
Assuming that's the case complete the following steps:
- Create a role
- Set Type to 'A set of data related to the record'
- Set Object to 'PO' (my assumption is the deliverto attribute is on the PO object. If that's not the case, insert the attribute's object here)
- Set the value to ':deliveredto' (insert your attribute after the colon)
- Save the role and add to your Communication Template
With regards to your question about the PO/Receiving relationship, there is no receiving object. The Receiving application is built upon the PO object.
Please reach out if you have any additional questions.
Matt McGuire
Aquitas Solutions
