  • 1.  How to identify delta data (Insert,Upadate,Delete) from two snapshots
    Posted 07-23-2022 13:44
    Hello Experts,
    Please let me know if i have 2 data base snapshots and i want to identify changes made between a specific date range like Insert , Update and Delete, How can i query this?
    I know Maximo has an attribute called Changedate which holds the cahnge information but this attribute s not present in most of the related objects.
    For example in SPAREPART object there is no changedate information so whenever a new sparepart added to Asset how can i identify and track this change.
    Similarly if something gets removed from sparepart how can i track .
    FYI i need this information to prepare data migration SYNC approach.
    #Architecture
    Pradeep Rout
    TCSL
  • 2.  RE: How to identify delta data (Insert,Upadate,Delete) from two snapshots
    Posted 07-25-2022 16:53
    Hi Pradeep, Usually, this is something you would pre plan prior to requiring the information for diff'ing a db. What do you mean snapshot? If that's two full db backup's, there are tools that can diff your db...
    keith simmons
    Aquitas Solutions
  • 3.  RE: How to identify delta data (Insert,Upadate,Delete) from two snapshots
    Posted 07-26-2022 02:34
    Hi Keith,
    Thanks for your response.
    Yes snapshot means two full db backup's taken on different intervals.
    Pradeep
    Pradeep Rout
    TCSL
  • 4.  RE: How to identify delta data (Insert,Upadate,Delete) from two snapshots
    Posted 07-26-2022 10:43
    so, the question becomes, what is the db vendor and are you comparing the schema, the data or both? There are tools available for MS SQL. I seem to remember there are more generic tool sets too. I'm not clear if this is an on going dynamic update requirement (in which case you might use the MIF), or a point in time where there are two dissimilar schemas where you would like to sync the underlying data...
    keith simmons
    Aquitas Solutions
  • 5.  RE: How to identify delta data (Insert,Upadate,Delete) from two snapshots
    Posted 07-28-2022 08:20
    Hi Pradeep,
    The simple answer is ROWSTAMP.  However, that does not tell you what was changed only that there was a change.  Good luck with your efforts.
    ISW
    Maximo Practice Manager
    eMail: ckokay@isw.net.au
    Phone: +61-411-682-040
    #IBMChampion2022
  • 6.  RE: How to identify delta data (Insert,Upadate,Delete) from two snapshots
    Posted 07-28-2022 13:25
    So, you could simply write procedures in what ever db(s) your using, or you could use a tool like SQL Examiner, or the tools provided with MS SQL Server, however, if this is a Maximo application db, there are other considerations regarding the data that is the application meta data definitions and possibly corresponding static and transactional data. There isn't enough information in your messages to ascertain the scope of what you want to do, so the assumption that simply copying data from A to B is optimistic at best. But that's just me...
    keith simmons
    Aquitas Solutions
  • 7.  RE: How to identify delta data (Insert,Upadate,Delete) from two snapshots
    Posted 08-30-2022 21:37
    Edited by sun kim 08-30-2022 21:39
    If you want to track the delta of spareparts, you can turn on eAudit.
    https://bportaluri.com/2016/11/tracking-changes-using-audit-feature.html
    This creates an audit table that will track your insert, update, and deletes. Specify what columns you want to track so you limit the data you want to track.
    If you really want to torture yourself with comparing data on the table level feel free, but I don't feel it is an efficient approach since you are separated from the data context. Unless you know how the Maximo data is structured, reviewing the differential may not be so helpful. If the purpose is to reconstruct data during a cut-over period, eaudit could work better for you.
