  • 1.  Maximo Time Out: Can you set the auto log out time duration within Maximo?
    Posted 02-07-2024 17:01
    • Is there a way to set up how many minutes before the system logs you out?
      • Has this helped with App Points usage going back to the pool when a user is inactive?
    Thank you
    #Security
  • 2.  RE: Maximo Time Out: Can you set the auto log out time duration within Maximo?
    Posted 02-08-2024 10:23
    Danny
    We just had our system set to auto log out to 15 minutes of inactivity. We're not yet using App Points but do have some concurrent licenses and made the change to eliminate any overages in license use.
    Gina Ordaz
    Idaho Milk Products
  • 3.  RE: Maximo Time Out: Can you set the auto log out time duration within Maximo?
    Posted 02-08-2024 10:31
    Understanding Maximo timeout values - web.xml session-timeout and usermonitor (ibm.com)
    Configuring session timeout periods - IBM Documentation (yeah, this is for Control Desk, but it's the same for Maximo)
    We're not on a version that uses App Points, so I can't answer authoritatively there.
  • 4.  RE: Maximo Time Out: Can you set the auto log out time duration within Maximo?
    Posted 02-22-2024 18:32
    Thank you @Travis Herron.  That article can help start me in the right direction.  I appreciate it.
