  • 1.  Spatial Start Center portlet?
    Posted 09-20-2022 13:07
    Greetings,
    Is it possible to put a map layer / viewer inside a result set start center portlet, for example "my work orders" but the map view of them (and then have the ability to click a pin on the map view and have it open the work order tracking application as the wolink would on a text result set portlet)?
    Similar, is it possible to have the List tab of a power app application be a map view by default?
    Making maximo map centric...
    #Spatial
    Robert Matthews
    Itam
  • 2.  RE: Spatial Start Center portlet?
    Posted 09-21-2022 09:14
    Hi Robert,
    You can view multiple markers on the map tab of an application following the below link:
    https://www.ibm.com/support/pages/ability-view-multiple-markers-map-maximo-scheduler-751
    This work for power apps map tabs only. Maximo Start center does not support map yet.
    If you have spatial then you should be able to use the spatial features on the map.
    Only limitation with this is your list tab resultset should be less than 200 records .
    Biplab Choudhury
    BPD Zenith Australia
