  • 1.  Where to find maf-tools for 9.1?
    Posted 11-07-2025 11:28
    I had been going here https://www.ibm.com/support/pages/configuring-and-customizing-ibm%C2%AE-maximo%C2%AE-mobile#example3-tab11  and using the image number field to pull the version of maf-tools I needed, but for 9.1 it just says "9.1 (Included with Maximo Application Suite deployment". Is there a different method of finding which version to download for whatever patch of 9.1 you are using?
    Andy
  • 2.  RE: Where to find maf-tools for 9.1?
    Best Answer
    Posted 11-09-2025 19:46
    MAF is now built-in withing MAS 9.1 and will not require docker to download and run images. Have a look into the following:
    Configuring Application Configuration v9.1 - IBM Documentation
    Niv Geo
  • 3.  RE: Where to find maf-tools for 9.1?
    Posted 11-10-2025 08:48
    Thank you! It's no wonder I couldn't find it.
    Andy
  • 4.  RE: Where to find maf-tools for 9.1?
    Posted 11-13-2025 14:36
    Hopefully you have better luck with it than we are. Its been nothing but a headache since they've merged the tool into Maximo.
    Andrew Weaver
    TechAdept Solutions
  • 5.  RE: Where to find maf-tools for 9.1?
    Posted 11-15-2025 19:23
    Yes, After merging, it's full of bug right now. Preview does not work and fix for the same is yet to be released. For any code testing, you need to publish the changes.
    Ritesh Ranjan
    Wipro
