  • 1.  JSON Mapping application for outbound processing is not recognizing array element in json message
    Posted 02-06-2025 18:24
      |   view attached
    JSON Mapping application for outbound processing, it is not showing array element in target property selection window. See attachment for screenshots.
    This is happening in Maximo 7.6.1.3
    Chandra Karumuri
    Oncor
    Attachment(s)
  • 2.  RE: JSON Mapping application for outbound processing is not recognizing array element in json message
    Posted 02-07-2025 21:52
    Edited by Prashant Sharma 02-07-2025 22:10
    Hi Chandra
    Your format is incorrect. Here ix example format that you need to use-
    "BFASSETID":"JMP15",
    "BFSITEID":"BEDFORD",
    "BARRY":[
        "BTEST1":"TEST1",
        "BTEST2":"TEST2",
        "BTEST3":"TEST3"
    And you will be able to see Array elements as well which should be mapped with Child Object.
    Sedin Technologies
    Learn Maximo with me @https://www.youtube.com/@reliabilityodyssey/
    #IBM Champion 2022
    #IBM Champion 2023
    #IBM Champion 2024
  • 3.  RE: JSON Mapping application for outbound processing is not recognizing array element in json message
    Posted 02-08-2025 12:14
    Hi Prashant,
    Thanks for your response. No issues with object type arrays like below, in the example BARRY is a structure(object).
    "BARRY":[
        "BTEST1":"TEST1",
        "BTEST2":"TEST2",
        "BTEST3":"TEST3"
    In my case BARRY is a array of element and it is valid json message.
    "BARRY":["BTEST1","BTEST2"]
    Chandra Karumuri
    Oncor
  • 4.  RE: JSON Mapping application for outbound processing is not recognizing array element in json message
    Posted 02-09-2025 10:37
    Edited by Prashant Sharma 02-09-2025 10:43
    Not a valid format for showing attribute lookup.
    IBM Champion 2022|2023|2024|2025
    Lets learn MAS @ https://www.youtube.com/@reliabilityodyssey/
  • 5.  RE: JSON Mapping application for outbound processing is not recognizing array element in json message
    Posted 02-10-2025 11:36
    Oh okay, so Maximo doesn't support JSON mapping for Array elements.
    Chandra Karumuri
    Oncor
