  • 1.  Reserved Items
    Posted 04-08-2024 15:19
    We're using Maximo 7.6.2. We're using PM's to reserve items. When items are issued to the PM/WO, unless the status of the WO is changed to complete the item remains reserved.
    Has anyone else had this and other than changing the status of the work order, once the items are issued to the work order, have you been able to get the reservations to update without changing status of the work order?
    In our case, procurement/inventory issues the items to the work order. But until the status of the work order is changed to complete the item is still reserved for that work order.
    Any help you can give would be appreciated.
    Gina
    #Procurement
    Gina Ordaz
    Idaho Milk Products
  • 2.  RE: Reserved Items
    Posted 04-09-2024 08:14
    Edited by Christopher Winston 04-09-2024 08:30
    Did you check your org setting? I think the default is to clear reservation on work order close
    You want the 'To Complete' radio button to be selected
    Go to
    in Organizations
    A useful reference can be found at https://www.projetech.com/maximo-blog/organization-options-work-orders
    IBM Champion 2024
  • 3.  RE: Reserved Items
    Posted 04-09-2024 10:19
    Christopher
    Our system is set to clear the reservation when the work order is changed to complete. The only other option available is when the work order is closed. The issue I have is that we stage parts and issue at that time. Because the inventory clerk isn't changing the work order to complete the item(s) are still reserved which calls for more orders when they aren't needed.
    Gina Ordaz
    Procurement Manager | Idaho Milk Products
    Office 208-644-2889 | Cell 208-490-6198 |Email gordaz@idahomilk.us
  • 4.  RE: Reserved Items
    Posted 04-09-2024 08:48
    As Christopher has pointed out, definitely check the Org setting.  It sounds like you already have that set to "On Complete."  Other than that, AFAIK, a reservation should end when the Item is issued in the correct (the reserved) Quantity from the correct Storeroom.  So it kinda sounds like maybe there's something astray in the process -- most likely issuing it from a different Storeroom.
    I'd look into this: when Procurement/Inventory makes the issue transaction, how are they doing it?  Which UI screen (Work Order Tracking --> Actual Materials, Issues & Transfers, Inventory --> Issue Current Item, Inventory Usage record)?  Which buttons are they using (New Row, Select Reserved Items, etc.)?
    Are you seeing this problem on every Reservation, or just some?  If just some, you'd have to find the common pattern.  Look closely at the Storeroom, Quantity, Conversion factor, logged-in user, Itemnum, and what "billing info" was used -- assetnum, location, gl account, wonum.
  • 5.  RE: Reserved Items
    Posted 04-09-2024 10:23
    Travis,
    You are correct that our Org setting is set to "On Complete".  I think that the inventory clerk is issuing direct from the inventory screen. I'll do some trials using different methods in our test system to see if any specific method releases the reservation. Thanks for the help.
    Gina Ordaz
  • 6.  RE: Reserved Items
    Posted 04-09-2024 10:48
    Interesting; I don't think I've ever done it that way, so I'm intrigued to see what you find.  Just trying to take a look at it, doing it that way, the Inventory application calls the Issue Current Item dialog box, which is built on a Relationship called ISSUECURRENTITEM.  The ISSUECURRENTITEM non-persistent table, judging by the fields/attributes it includes (that is, I'm not looking at JavaDocs), doesn't have anything that makes me think it is looking at or considering Reservations.  Other ways that we typically issue parts, such as Issues & Transfers or on Work Order Actuals, use a relationship to the MATUSETRANS table, which does have a Reservedqty field.
    So I suspect issuing it from an Inventory record isn't considering Reservations at all, and that's why you're getting the result you're getting.  But I could be wrong, never tried it in real life.
  • 7.  RE: Reserved Items
    Posted 04-09-2024 13:35
    Travis,
    You are exactly right. When issuing in the inventory application it does not take into account reservations. But, when issued from the work order application and selecting reserved items to issue from everything updates properly. We've been struggling with this for a number of yearsL Now to clean up our mess and start with the new and improved procedure!  I'm excited to get there.
    Gina Ordaz
  • 8.  RE: Reserved Items
    Best Answer
    Posted 04-09-2024 20:29
    Hi Gina,
    I went OMG when I saw the process being used.  I'd like to layout the intended applications that can be used to issue a reserved item.
    1. Inventory Usage.  This is the prime application designed for in the Storeroom to issue, transfer, stage items.
    2. Manage Inventory.  This is the new version of the Inventory Usage application using the new generation of screens.  This is also designed for the storeroom, but if used on a tablet, in effect it's also mobile (connected solution only) where the barcode|QR scanner can be used.
    3. Issues and Transfers.  This is the old version of Inventory Usage, but does not have the staging function.  This is also designed for the storeroom.
    4. Work Order Tracking or Quick Reporting.  This is the prime applications used by maintenance personnel.
    5. Maximo Mobile.  We'll this is the mobile option that can use the barcode|QR scanner to get the item.  Can be used by maintenance or storeroom.
    In most cases, there is a Select Reserved Items button expect for Manage Inventory (where it's an actual tab in that application) where you select the reserved item for issuing.  If anyone, instead chooses and item without using that button, well, Maximo doesn't know that you are really issue one off the reservation.... because you haven't selected one of the reservation list.
    Principal Consultant
    COSOL
    #IBMChampion
  • 9.  RE: Reserved Items
    Posted 04-10-2024 10:26
    Craig
    I'm sure some of how we do things was born out of survival. I welcome the information you provided. I'll share this with my group, and we'll add this to our instructions and SOP list.
    Thanks so much for your help.
    Gina Ordaz
    Idaho Milk Products
