  • 1.  Can you tell when a Manual generation of a PM Work Order has occurred?
    Posted 03-03-2023 14:43
    Is there a flag that is set somewhere so you can tell if the PM Work Order was manually generated?
    Wade Redd
    3rd Coast Consulting
  • 2.  RE: Can you tell when a Manual generation of a PM Work Order has occurred?
    Posted 03-05-2023 22:18
    No there is no flag out of the box but you can manually set a flag(yorn) when it’s generated using Generate Workorder select action .
    Thanks & Regards
    Venkat
  • 3.  RE: Can you tell when a Manual generation of a PM Work Order has occurred?
    Posted 03-06-2023 11:02
    Thank you
    Wade Redd
  • 4.  RE: Can you tell when a Manual generation of a PM Work Order has occurred?
    Posted 03-06-2023 11:31
    If a user invoked the action menu > Generate Work Orders, the reported by field will be populated with that user's ID.
    Lani Trotter
    Starboard Consulting LLC
  • 5.  RE: Can you tell when a Manual generation of a PM Work Order has occurred?
    Posted 03-06-2023 11:53
    Thank you Lani,
    I assume that is on the work order tracking panel?
    Wade Redd
  • 6.  RE: Can you tell when a Manual generation of a PM Work Order has occurred?
    Posted 03-06-2023 12:09
    Yes.  Typically, in the Responsibility section:
    Lani Trotter
  • 7.  RE: Can you tell when a Manual generation of a PM Work Order has occurred?
    Posted 03-09-2023 12:42
    I'm on 7.6 so it looks a little different
    Wade Redd
