  • 1.  Log4j not work when upgrade Max761 to max8
    Posted 12-18-2023 18:27
    Edited by Eric Zuo 12-18-2023 19:53
    Hello All,
    We have customized java programs worked well in Max7.6.1, now we are upgrade Maximo to MAX8, I am trying to port the eclipse java project for Max8.   We use the new jar from MAX8 lib folder. Fro example, log4j.jar is removed, replaced  by log4j-api-2.17.1.jar and log4j-core-2.17.1.jar.
    import org.apache.log4j.FileAppender;
    import org.apache.log4j.net.SMTPAppender;
    is replaced by
    import org.apache.logging.log4j.core.appender.SmtpAppender;
    import org.apache.logging.log4j.core.appender.FileAppender;
    But we got a lot of errors, the log4j is a significant and complicated one.:
    The FileAppender constructor in log4j.jar takes 2 parameters , and in Max8 lib, it takes much more parameters.
    I may need to rewrite our functions . Anybody has successful approach or good document for this kind  issue?
    What value should be set for the following attributes required by org.apache.logging.log4j.core.appender.FileAppender.class :
    private boolean locking;
    private boolean advertise;
    private String advertiseUri;
    private boolean createOnDemand;
    private String filePermissions;
    private String fileOwner;
    private String fileGroup
    In addition, I would like to know should we only use the lib from MAX8 lib? for example, for log4j, can we still use the log4j.jar in MAX8?
    please help.
    Eric
    #Architecture
    #Utilities
    Eric Zuo
    San Francisco Bay Area Rapid transit
  • 2.  RE: Log4j not work when upgrade Max761 to max8
    Posted 12-19-2023 12:08
    Eric,
    You probably want to use the FileAppender.newBuidler() method to get a FileAppender.Builder that can be used to build your file appender with desired attributes, something like the following:
    FileAppender.Builder b = FileAppender.newBuilder();
    b.withFileName("myfile");
    b.withAppend(true);
    b.setName("my-appender");
    b.build();
    FileAppender fa = b.build();
    Jason
    Jason VenHuizen
    Sharptree
  • 3.  RE: Log4j not work when upgrade Max761 to max8
    Posted 12-19-2023 16:13
    HI Jason,
    I updated the code as you pointed, fixed a lot of error related to SmtpAppender and FileAppender . Thank you very much.
    Then another error occurred. the line 68 which is the line 61 in the screen shot above.
    If change the line 68 as suggested, getLogBuilder requires Level as parameter. But how to get the Level (debug, error,..)
    could you please help again?
    The import for log4j2 is:
    import org.apache.logging.log4j.core.Logger;
    import org.apache.logging.log4j.core.Layout;
    Eric
    Eric Zuo
  • 4.  RE: Log4j not work when upgrade Max761 to max8
    Posted 12-19-2023 16:23
    Looks like Level.LOG_LEVEL are constants. For example: Level.DEBUG or Level.ERROR etc.
    https://logging.apache.org/log4j/2.x/manual/customconfig.html
  • 5.  RE: Log4j not work when upgrade Max761 to max8
    Posted 12-20-2023 13:00
    Hi Jason,
    for the error in line 68 in the screen shot above, if I follow the suggested ,   changed the getLogger(String str)   to  getLogBuilder(Level level) , but  the Level is set in Maximo logging app,  I should get it from Maximo, then how to get the level from maxim.  even I use a constant to test it, still not work:
    Therefore I doubt the suggested "Quick fix" is incorrect.
    Please forward instruction .
    Eric
    Eric Zuo
  • 6.  RE: Log4j not work when upgrade Max761 to max8
    Posted 12-28-2023 04:52
    Hi Eric,
    Is there a specific reason why you are not letting Maximo manage the loggers for you?
    Presumably you are making a connecvtion to the MXServer object for your work, or the code is running within Maximo.
    If either of those statements is true then your code can just ask the MXServer object for a specific logger and the MXServer object manages everything for you e.g. the log level, managing the log4j code.
    mark robbins
    Cohesive
  • 7.  RE: Log4j not work when upgrade Max761 to max8
    Posted 01-05-2024 18:37
    Hi Mark,
    Now we changed the log to MXLogger, resolved the issue.
    Thank you.
    Eric
    Eric Zuo
