Query by dynamic date range
  • 1.  Query by dynamic date range
    Posted 06-08-2022 10:37
    How would I write a front-end query for Reporting to find work orders by the previous week.  I would like it to be dynamic, so that each time it runs it only shows the previous week's work orders by their initial creation date (WORKORDER.REPORTDATE).  I'd also like to expand this to a monthly query eventually.  I'm a SaaS environment so this would have to be through the Queries application which is fine.
    Ryan Sheeler
  • 2.  RE: Query by dynamic date range
    Posted 06-08-2022 11:21
    Hi Ryan,
    Try using below query
    createddate between sysdate- 7 days and sysdate
    PAVAN KUMAR
    Maximo Consultant
  • 3.  RE: Query by dynamic date range
    Posted 06-08-2022 11:29
    here is my Where clause from the Adv Search in Work Order Tracking.
    ((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and historyflag = 0 and istask = 0)
    Can your addition go in there so it would look like this?4
    ((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and historyflag = 0 and istask = 0 and createddate between sysdate- 7 days and sysdate)
    Ryan Sheeler
  • 4.  RE: Query by dynamic date range
    Posted 06-08-2022 11:59
    I think you are looking for reportdate, but at any rate, I just ran this to confirm on the 7.6 demo site
    ((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and historyflag = 0 and istask = 0 and siteid = 'BEDFORD') and reportdate between sysdate-7 and sysdate
    Works just fine
  • 5.  RE: Query by dynamic date range
    Posted 06-08-2022 14:54
    Thanks that was it - thanks for the help.   Eventually I'd like to extend it to show monthly or quarterly,  and CLOSED work orders instead of newly created ones too.
    Ryan Sheeler
  • 6.  RE: Query by dynamic date range
    Posted 06-09-2022 08:39
    @Ryan Sheeler What you may want to do is a Query Based Report, with runtime parameters. You will need your report administrator (which may well be you) to update the report after creation, to then add the parameters. An example is in the video:
  • 7.  RE: Query by dynamic date range
    Posted 02-22-2026 11:48
    a.  Can you add QBE to a work queue on operational dashboards.
    b.  What could you use for reporting by logged in users work group?
    As always, thank you.
    Maureen Holland
    NBC Universal
  • 8.  RE: Query by dynamic date range
    Posted 06-10-2022 16:46
    Thanks everyone - all of these are really helpful.  I'll probably end up using some of all of them in one way or another!
    Ryan Sheeler
  • 9.  RE: Query by dynamic date range
    Posted 06-08-2022 13:05
    Edited by Eric Godel 06-08-2022 13:04
    For Oracle Databases, sysdate will work just fine.  But for MSSQL use GETDATE() with DATEADD function something like this:
    ((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and historyflag = 0 and istask = 0 and reportdate between DATEADD(day,-7,GETDATE()) and GETDATE())
    I am not sure how to write it in DB2.
    thanks!
    Eric Godel
    Bay Systems Consulting
  • 10.  RE: Query by dynamic date range
    Posted 06-08-2022 13:24
    what database you are using?
    if you are using db2 then "((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and historyflag = 0 and istask = 0 and siteid = 'BEDFORD') and reportdate between sysdate-7 and sysdate" it works.
    confirm me what db you're using
    PAVAN KUMAR
    Maximo Consultant
  • 11.  RE: Query by dynamic date range
    Posted 06-08-2022 16:55
    I wonder if you could write the query in such a way that it could be prompted for a date range, instead of just returning the previous week from the sysdate?
    Ryan Sheeler
  • 12.  RE: Query by dynamic date range
    Posted 06-08-2022 17:06
    No way to do that in the where clause of an application to generate a prompt. A saved query could however be edited.
    A QBR could be edited in report administration as well, to get date prompts.
  • 13.  RE: Query by dynamic date range
    Posted 06-09-2022 07:23
    Hi Ryan,
    We use this query in Work Order Tracking to produce a weekly list of work orders created in the 7 days prior to the report date:
    ((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and historyflag = 0 and siteid = 'BARHBR' and istask = 0 and reportdate >= getdate() - 7)
    I'm not sure if that's the "best" or the most elegant way to do it, but it works for us!
    Hope that's helpful,
    Amy
    Amy Tellier-Briggs
    Maintenance Planner, CBO, BOC Level 1
    Facilities Services
    207.288.6356 t  |  207.266.4347 m
    amy.briggs@jax.org
    The Jackson Laboratory
    Bar Harbor, ME  |  Farmington, CT  |  Sacramento, CA
    www.jax.org
    The Jackson Laboratory: Leading the search for tomorrow's cures
    The information in this email, including attachments, may be confidential and is intended solely for the addressee(s). If you believe you received this email by mistake, please notify the sender by return email as soon as possible.
  • 14.  RE: Query by dynamic date range
    Posted 06-09-2022 09:02
    I run multiple reports for the previous month. I use a dynamic query that selects records where the date falls in the previous month in my automated reports. I change the data field to reflect the record set I am looking for.
    (woclass = 'WORKORDER' or woclass = 'ACTIVITY') and historyflag = 0 and istask = 0 and workorder.reportdate >= add_months(trunc(sysdate, 'MON'),-1) and workorder.reportdate < trunc(sysdate, 'MON')
    I run my reports for multiple sites so I do not include a siteid. We are using Oracle.
    Kevin Egolf
    TechOps
  • 15.  RE: Query by dynamic date range
    Posted 06-10-2022 09:13
    Hi Ryan
    I think the following would give you the previous calendar weeks reported work orders (for Oracle db):
    historyflag = 0 and istask = 0 and reportdate >= trunc(sysdate, 'IW')-7 and reportdate < trunc(sysdate, 'IW')
    Kind Regards
    Phil
    Phil Naylor
    MACS EU
  • 16.  RE: Query by dynamic date range
    Posted 01-31-2024 09:34
    For what it is worth, you could I suppose create a custom app to make it dynamic by creating an app to manage dates. If it just for work orders maybe add a new Tab in Work Order Tracking.  I played in our development and used existing custom app. Although it isn't a simple pop up prompt it would probably be easier then opening a saved query and modifying.
    my saved where clause looks like reportdate between (select to_date(userlist.colval1,'MM/DD/YYYY') and (select to_date(userlist.colval2,'MM/DD/YYYY') from userlist where value = 'DYNDATE')
    Wes Williams
    Northrop Grumman
