  • 1.  Reports for Mean Time to Repair (MTTR) and Mean Time Between Repairs (MTBR)?
    Posted 01-24-2024 10:38
    I'm new to Maximo and this forum.  Are there basic reports available for MTTR and MTBR?
    Maintenance closes about 50 corrective repairs a month.  Service Request dates are somehow separate from the Work Order closure date.
    Any help is appreciated!
    Ken Trotta
    Sequoia Consulting Group
  • 2.  RE: Reports for Mean Time to Repair (MTTR) and Mean Time Between Repairs (MTBR)?
    Posted 01-24-2024 11:04
    MTTR and MTBR fields are calculated by work order.  User has to report downtime on the asset.  MTTR/MTBR fields will never display if downtime on an asset is not reported.  I did not see any MTTR/MTBR reports from OOB.  We created a package that calculates the rollup throught Asset Utilities.  Here is a breakdown you can do manually.
    For the example below we will use Siteid = BEDFORD and Asset # G1283
    Mean Time To Repair (MTTR) formula is (Total Production Downtime) divided by (Number of Breakdowns)
    The MTTR will be a decimal number for example: 96.05, which depicts 96 hours and 3 mins. Because the code in this program requires 2-point decimal presentation, what you will do is divide 3 into 60 you get .05.  To double-check your calculation compute .05 of an hour (60X.05) you get 3, which perfectly correlated with the minutes in the YTD Downtime field.
    Example:
    On 03/04/2020 the equipment went down at 6:32 pm (1832 military time) and you need to subtract this from 24 hours. It is easiest to let SQL do that calculation for you.  The select for that is:
    SELECT (to_date('02/21/2020 07:10:00','MM/DD/YYYY HH24:MI:SS') - to_date('02/20/2020 16:24:49','MM/DD/YYYY HH24:MI:SS')) * 24 FROM DUAL
    Your most recent date goes first, the oldest date goes second. For this we are just looking to see how many hours the asset was down on March 4th.
    The first date in the select will be Mar 5th at midnight. Midnight will be displayed as 00:00:01 which is actually 1 minute after midnight, but that is the only way we can get SQL to calculate it.
    The 2nd date will be Mar 4th with the time it went down expressed in a 24 hour clock time.
    The select gives us 5.457 hours of downtime. Converting the .457 to minutes would be 5:27 (rounding does play a part here. I'm not too concerned if we are off by a minute, but much over that, gives cause for concern.)
    From the 5th – 6th of Mar the system was down for 48 hours, so the math would be 24 hours X 2 days = 48 hours
    48:00 hours + 5(hours):27 (mins) = 53:27
    Now you need to calculate for the rest of March. Based on the calendar, there are 17 days left that the asset is supposed to be up for 24 hours each day. 24:00 x 17 = 408 hours.
    Total downtime for March is 461:27 hours.
    The total downtime for April = 22 x 24 = 528 hours
    The total downtime for May = 20 x 24 = 480 hours
    The total downtime for June = 22 x 24 = 528 hours
    We have to calculate the downtime for July just like we did for March. The first date in the select statement will be 07/20/2020 07:39:00 and the 2nd date will be 07/01/2020 00:00:01. That gives us 463.64972 or 463:39
    Then we actually have another 'break' in July for 1 minute. Since it is just a minute, we will actually just add it in. If it was longer and we needed to calculate using TOAD we would. But your Total downtime for July is 463:40
    Total Downtime for the entire period for this asset is for all months added together = 2293:07, converted to tenths of an hour, 2293.116
    The last number we need is the Total Production time. This is found by looking at the calendar for the asset for the month in question. For this example, the EQQ54-C for July 2020, shows 22 days for 24 hours on those days. So Total Production time = 22 x 24:00 = 528.
    Now you have the values you need to calculate both MTBF and MTTR for the asset.
    ·         Calculate Mean Time Between Failure and record in the Record Event column.
    MTBF: (Total Production time – Total Downtime)/# of Breaks
    Total Production time = 528 (for each month)
    Total Downtime = ea month
    # of Breaks = each month
    Mar - (528 – 461.27)/1 =  66.73
    Apr – (528 – 528)/1 =  0.0
    May –  (528 – 528)/1 =  0.0
    Jun –  (528 – 528)/1 =  0.0
    Jul – (528 – 463.40)/2 =  32.3
    ·         Calculate Mean Time To Restore and record in the Record Event column.
    MTTR: Total Downtime/# of Breakdowns
    Total Downtime = 2293.116
    # of Breaks = 2 (asset came up twice in the month of July)
    2293.116/2 = 1146.558 or 1146.01
    Hope this helps!
    A.S. Bearden
    A.S. Bearden, GDIT
    'ADAM'
  • 3.  RE: Reports for Mean Time to Repair (MTTR) and Mean Time Between Repairs (MTBR)?
    Posted 01-25-2024 09:17
    Hi Adam, Thanks for the reply.
    The downtime clock starts when the corrective service request is submitted.  The downtime clock stops when the work order is closed by the supervisor.  That means the asset is officerly returned to service.   It seems so simple but somehow there is no canned report writer in Maximo.
    Its shocking a "maintenance management" software can't instantly provide this simple basic metric.  How often does an asset need a repair?  How long do those repairs take?  What did the repairs cost?
    Ken
    [Ken] [Trotta]
    Gilead Sciences
  • 4.  RE: Reports for Mean Time to Repair (MTTR) and Mean Time Between Repairs (MTBR)?
    Posted 01-26-2024 14:30
    There are a couple of OOB reports detailing Asset downtime. In the Maximo Asset application 'Details of Asset Failures by Location' is described Pie Chart highlights greatest number of Failures by Problem Code.  The report data is sorted in descending order of # of Failures, and includes Most Recent Failures and MTBF Data for selected Asset.  By clicking on a Problem Code, can drill down into Drilldown of Asset Failures Report.
    Drilldown into Asset Failures - Presents historical view of downtime hours for selected problem code.  Along with the fail date, the  report data also lists the cause and remedy of each problem.  Hyperlink available on WO # to attain more details of last failure.
    Both of these can be tweaked for additional information or calculations.
    NORMA RAMEY
  • 5.  RE: Reports for Mean Time to Repair (MTTR) and Mean Time Between Repairs (MTBR)?
    Posted 01-29-2024 09:29
    Hi Norma,
    This facility does not use failure codes.  Unless its chronic or otherwise expensive there is no root cause analysis and the mechanics usually don't know why it failed.  "Other" is the most common failure code I've seen in biotech.  I will try these reports with the business management and IT people. Thank you!
    Ken
    [Ken] [Trotta]
    Gilead Sciences
  • 6.  RE: Reports for Mean Time to Repair (MTTR) and Mean Time Between Repairs (MTBR)?
    Posted 01-26-2024 15:34
    It's been 20+years working with Maximo now, and not once in those years have I encountered a definition of MTTR/MTBF that is the same across the organization, much less across an industry.  It's so much fun.
    The most common I've seen in WO Create Time ("Report Date") to WO Completion Time (Time when the WO is stamped "COMP") is the MTTR.   WO's have to remain open enough to record material and labor transactions and other activities that happen after tools down.  You can't do any of them if the WO is CLOSE.
    In the case of Service Requests, things get dimensionally more complicated.
    What happens when 3 SRs are created for the same issue but at different dates, and one WO is dispatched to address all three?  What if the SR is created before the asset is non-functional or down?  How does SR create time figure into this?
    Without consistent definitions, IBM has not gone out of the way to create canned anything's.  With 10's of 1000's of customers, that would be impossible to maintain if the definitions of Asset UP, Asset DOWN and Work Complete are different everywhere.
    I hear and live your struggle.
    The best answers I've had are to follow the wrench.
    • An SR is one beginning, but not all of them (PMs, Condition Monitoring, External triggers, etc)
    • MTTR starts when the failure occurs, and that event is rarely when the life of a WO begins.
      • Downtime reporting is one of the best tools for that, but it does require diligence.
      • The only real take here is that it must be consistent.
      • My preference is to use WO.REPORTDATE.  That's when the WO's life begins and it's a pretty good constant.
    • MTTR ends when WO goes to COMP, or at ACTFINISH.
      • I prefer ACTFINISH myself (with an eAudit) as the actual return to service time rarely coincides when someone gets around to markign the WO complete.
    Enjoy the journey, and the maths of time!
    Scott Mahon
    Scott Mahon
    Scott J Mahon Holdings Ltd.
  • 7.  RE: Reports for Mean Time to Repair (MTTR) and Mean Time Between Repairs (MTBR)?
    Posted 01-29-2024 09:17
    Hi Scott,
    Great answers!  Thank you.  IBM could choose one of the SMRP definitions for MTBF or MTTR and make it a canned report.  If there were three corrective SR's for the problem whichever was flipped to the WO, use that date.  Having the perfect start date may be the enemy of good enough
    A corrective SR can sit for days or more before Planning makes it a WO – that may be the "good enough" part.  Using WO.REPORTDATE.  MTTR ends when WO goes to COMP, or at ACTFINISH.  Might be a good compromise.  Thank you.  "Follow the wrench" as you say.
    Ken Trotta
    Principal Reliability Engineer
    Sequoia Biotech Consulting
