  • 1.  Report: Print with attachment problem.
    Posted 01-10-2024 21:52
    Hello Everyone,
    I am facing with function "Print with attachment" report problem, when I attach a PDF file that use E-Signature in the content and run  "Print with attachment", maximo raise an error "
    Errors encountered. For details of the error note current time and ask your system admin to check server log. Error:ERROR: Could not merge all files. Ask administrator to check server log".
    Any Suggestions/inputs please
    Thanks and Regards.
    [Acey] [Nguyen]
    [NGS]
  • 2.  RE: Report: Print with attachment problem.
    Posted 01-11-2024 00:43
    Here is Technote from IBM about this error-
    https://www.ibm.com/support/pages/pdf-attachments-maximo-record-are-not-printed-direct-print-attachments-action-if-they-include-incorrect-trailer
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 3.  RE: Report: Print with attachment problem.
    Posted 01-11-2024 02:47
    Thank Prashant Sharma, that mean there is no other way to handle this error? For example repairing the PDF file, etc.
    [Acey] [Nguyen]
    [NGS]
  • 4.  RE: Report: Print with attachment problem.
    Posted 01-12-2024 11:49
    Edited by Joe Kelley 01-17-2024 12:39
    I got same error and IBM mentioned that is fixed on MAS, but they doesn't have plans to do it for MAM. Hope IBM replaces that 3rd party component!
    I was trying to identify the "bad" trailer, bue I can't find which exactly is.
    Carlos Galindo
    NC
  • 5.  RE: Report: Print with attachment problem.
    Posted 01-14-2024 21:14
    Hi Carlos Galindo, Do you have the link from IBM that mentioned about fixing this error on MAS?
    Thanks.
    [Acey] [Nguyen]
    [NGS]
  • 6.  RE: Report: Print with attachment problem.
    Posted 01-17-2024 12:39
    At this time, I haven't found any public document from IBM.
    I raised a case and this is the conclusion. Hope it helps you.
    We have been checking internally and have come to a conclusion.
    Unfortunately, not all attachments uploaded to the Case, as you know, worked for TPAE 761.x, that is, the iText Software (Library) is unable to convert all Scanned files, as I had previously mentioned.
    That said, we released our new versions of Maximo Application Suite 8.x, and fixed this problem by using the GroupDocs Converter Software (Library), which when tested in our Lab with its Attachments, all worked as expected.
    Our best suggestion at the moment would be to encourage you to Upgrade to the Maximo Application Suite 8.x, where you will no longer face these types of problems. But, we are aware of the Companies' Bureaucracies, in choosing to continue with the Maximo TPAE 761.X. Therefore, we recommend that you upgrade to the most recent version of TPAE, which is 7613, as version 7612 will become Obsolete from January onwards, where corrections will no longer be released.
    With this, we could make a request to the Dev team, so that they evaluate the possibility of updating this iText Library to the GroupDocs Converter, but we cannot guarantee that this will be effective.
    Carlos Galindo
    NC
  • 7.  RE: Report: Print with attachment problem.
    Posted 02-14-2024 21:59
    Thank Carlos Galindo, I have found the problem, that is mxe.report.passDatabase system property, the value is set to 0 instead of 1.
    [Acey] [Nguyen]
    [NGS]
  • 8.  RE: Report: Print with attachment problem.
    Posted 11-28-2024 18:40
    Hi everyone,
    I'm facing the same problem. Could you please help? I changed the value of mxe.report.passDatabase from 1 to 0, but after that, I can't print my report with the attachment. Do you have any other solutions?
    EL OUAHABI Soufyane
    SQLI
