Publish channels and Reports
  • 1.  Publish channels and Reports
    Posted 08-19-2025 07:21
    Our company is PDF-driven for record retention. Is it possible to export report PDF's using the MIF? For example, we are hoping to use an event (status changed to close) to then export the record's report (like woprint for work orders). The REST API works fine to pull reports, but we're hoping for a push.
    Jason Johnson
    RSI
  • 2.  RE: Publish channels and Reports
    Posted 08-19-2025 10:44
    Your best option would be to run the report from an automation script on the desired event. For example, when POs are approved, I have seen customers automate a send of the PO report to the vendor. An example script to execute the report & store as an attachment is below. You could change this to send an email or push the file some other way to another system.
    from com.ibm.tivoli.maximo.report.birt.runtime import ReportParameterData
    from com.ibm.tivoli.maximo.report.birt.admin import ReportAdminServiceRemote
    from com.ibm.tivoli.maximo.oslc.provider import AttachmentStorage
    reportAdminService = MXServer.getMXServer().lookup("BIRTREPORT")
    whereclause="assetnum='11430'"
    parameterData = ReportParameterData()
    parameterData.clearAllParameters()
    parameterData.addParameter("where", whereclause)
    fileName="testfile.pdf"
    reportBytes = reportAdminService.runReport(MXServer.getMXServer().getSystemUserInfo(), "asset_detail.rptdesign", "asset",parameterData, fileName, ReportAdminServiceRemote.OUTPUT_FORMAT_PDF)
    assetSet=service.getMboSet("ASSET",MXServer.getMXServer().getSystemUserInfo())
    assetSet.setWhere(whereclause)
    assetMbo=assetSet.getMbo(0)
    doclinkSet=assetMbo.getMboSet("DOCLINKS")
    docStore=AttachmentStorage.getInstance()
    doclinksMbo = doclinkSet.add()
    newFileName=docStore.getAttachmentQualifiedName(doclinksMbo,fileName)
    docStore.createAttachment(newFileName,reportBytes,"application/pdf")
    doclinksMbo.setValue("URLTYPE", "FILE")
    doclinksMbo.setValue("URLNAME", newFileName)
    doclinksMbo.setValue("NEWURLNAME", newFileName)
    doclinksMbo.setValue("DOCTYPE", "Attachments")
    doclinksMbo.setValue("ADDINFO", True)
    doclinksMbo.setValue("DESCRIPTION", "Test report", doclinksMbo.NOACCESSCHECK)
    doclinksMbo.setValue("PRINTTHRULINK", False,doclinksMbo.NOACCESSCHECK)
    assetSet.save()
    assetSet.cleanup()
  • 3.  RE: Publish channels and Reports
    Posted 08-19-2025 11:14
    That's some intense scripting, lol. Might take a while to digest. Thanks so much for the help!
    Jason Johnson
    RSI
  • 4.  RE: Publish channels and Reports
    Posted 08-26-2025 17:20
    When the script is run, it throws the following error. The security should be configured correctly (MAXADMIN user is in MAXADMIN group). We have SAML implemented and can't log in as the MAXADMIN user, so I can't tell if it would run manually.
    Jason Johnson
    RSI
  • 5.  RE: Publish channels and Reports
    Posted 08-27-2025 09:01
    The error message saying "workorder application" makes me think you used workorder instead of wotrack (or whatever the appropriate application is) in this section of the code.
    It's confusing but the thing after the report is the application you are "running" the report in. In the case of asset, the object & app name match but in work order, it should be wotrack or one of the clones.
  • 6.  RE: Publish channels and Reports
    Posted 08-27-2025 11:28
    Thank you, your response led me to the error. I had the incorrect app name in the code (workorder instead of wotrack).
    Last question would be is it possible to email this report as an attachment using a Communication Template in the script?
    Jason Johnson
    RSI
  • 7.  RE: Publish channels and Reports
    Posted 08-28-2025 08:52
    Edited by Jason Johnson 08-28-2025 11:04
    I was able to send the report in an email as an attachment. The only thing left is to run the report to attachments in the final PDF. I'll trade the full code I have for an answer :)
    from java.io import File
    from java.io import FileOutputStream
    from java.io import ByteArrayInputStream
    woMbo = mbo
    wonum = woMbo.getString("WONUM")
    # --- Run BIRT report ---
    parameterData.addParameter("where", "(WORKORDER.wonum='"+wonum+"')")
    fileName = "WO_%s.pdf" % wonum
    # Run report
        "woprint.rptdesign",
        "WOTRACK",
        parameterData,
        fileName,
    # --- Send Email ---
    toAddress = "abc@xyz.com"
    fromAddress = "maxadmin@ibm.com"
    subject = "Closed Work Order %s Report" % wonum
    body = "Attached is the full Work Order report (including attachments) for WO %s." % wonum
    filePath = File.separator + "tmp" + File.separator + fileName
    tempFile = File(filePath)
    fos = FileOutputStream(tempFile)
    fos.write(reportBytes)
    fos.flush()
    fos.close()
    MXServer.getMXServer().sendEMail(
        toAddress,
        None,
        None,
        fromAddress,
        subject,
        body,
        None,
        [filePath],
        None
    if tempFile.exists():
        tempFile.delete()
    Jason Johnson
    RSI
  • 8.  RE: Publish channels and Reports
    Posted 09-30-2025 09:14
    In case anyone else is interested, there is another method in the report admin service specifically for this.
    Maximo 7.6.1.2 API - ReportAdminService
    woMbo = mbo
    # --- Run BIRT report with attachments ---
    whereclause = "wonum='%s'" % wonum
    filePath = reportAdminService.runReportWithAttachments(
        "WOTRACK",
        parameterData,
        fileName,
    subject = "Record retention %s" % wonum
        toAddress,
        None,
        None,
        fromAddress,
        subject,
        body,
        None,
        [filePath],
        None
    Jason Johnson
    RSI
  • 9.  RE: Publish channels and Reports
    Posted 09-30-2025 22:54
    A Different Approach to Consider
    Using an escalation with a communication template and the report's attachment is considered one of the simplest and most maintainable methods for automating BIRT report delivery in Maximo.
    Why This Method Is Simpler
    • No Custom Code Needed:
      The whole process leverages Maximo's standard escalation and communication template features-no automation scripting or Java is required.
    • Point-and-Click Configuration:
      Escalations can be set up using the UI to monitor conditions and trigger emails, while communication templates handle message formatting and report attachments.
    • Easier to Maintain:
      Business users can adjust recipients, conditions, and template content without a developer. Reports are automatically attached if specified in the template.
    How It Works
    1. Create a Communication Template:
      • Specify the email subject/body, variable substitutions, and designate the report to be attached for the target record type.
    2. Set Up an Escalation:
      • Configure it to monitor the target objects (e.g., work orders with specific status).
      • Set the escalation action to send the communication template when the condition is met.
    3. Result:
      • When the escalation fires, Maximo automatically generates the BIRT report and attaches it to the outgoing email.
    FREDRICK NDWARU
    NBCUniversal
  • 10.  RE: Publish channels and Reports
    Posted 10-02-2025 08:23
    I understand the communication template / escalation process. But how do you specify the "woprint.rptdesign" as an attachment? It has to be generated at run time; it itself is not an attachment to the work order.
    Jason Johnson
    RSI
  • 11.  RE: Publish channels and Reports
    Posted 10-03-2025 08:58
    I missed your post communicating your successful test; the only missing component is the attachment.
    What's missing from your script is the code snippet below:
    assetSet.save()
    assetSet.cleanup()
    After modifying your script:
    1. Navigate to the Communication Template application
    2. Select the Communication Template > Attachment Folders Tab
    3. More than likely, the Attachment Document Folder exists
    4. Set the Send with Communication? flag to True (checked)
    5. Save
    6. Retest
    Theoretically, implementing these changes yields the expected behavior.
    FREDRICK NDWARU
    NBCUniversal
