BIRT 4.8 Error
  • 1.  BIRT 4.8 Error
    Posted 12-11-2023 09:25
    Good morning, fellow Maximo power-users!
    I hope you are all having an amaiong day! I'm currently facing an issue while working with BIRT 4.8 for Maximo, and I'm reaching out to the community for some assistance.
    In my report script, I'm trying to populate output columns and receiving the following error (I can provide the full output if required, this is just a snippet):
    BIRT Error
    // Add a line for each output column // The specific get method should match the data type of the output column. row["textfield"] = maximoDataSet.getString("textfield"); row["datefield"] = maximoDataSet.getTimestamp("datefield");
    However, I'm encountering an error, and I'm unsure how to resolve it. If anyone has experienced a similar issue or has insights into potential solutions, your assistance would be immensely valuable.
    The error message I'm receiving is not something I have much familiarity with, and I want to make sure I'm handling output columns correctly. Your expertise and guidance on this matter would be greatly appreciated!
    Thank you in advance for your time and assistance. Looking forward to discussing with you.
    I can provide any additional details as needed to help clarify my issue.
    Thank you very much,
    Phil
    #Analytics
    Philip Marrone
    Boston Children's Hospital
  • 2.  RE: BIRT 4.8 Error
    Posted 12-11-2023 11:42
    There doesn't seem to be an attached error. It usually gives you some kind of information on why the report failed.
    All I see is a generic script.
    Bob Kraus
    Missouri S&T
  • 3.  RE: BIRT 4.8 Error
    Posted 12-11-2023 11:47
    Thank you for your response, the stack trace error says:
    "org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "if (!maximoDataSet.fetch())
    return (false);
    return (true);":
    Fail to execute script in function __bm_FETCH(). Source:
    " + if (!maximoDataSet.fetch())
    return (false);
    return (true); + "
    A BIRT exception occurred. See next exception for more information.
    Wrapped com.ibm.db2.jcc.am.SqlSyntaxErrorException: DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=AS;SELECT w.WONUM ;AND, DRIVER=4.26.14 (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#1).
       at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:99)
       at org.eclipse.birt.report.engine.script.internal.DataSetScriptExecutor.handleJS(DataSetScriptExecutor.java:256)
       at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:143)
       at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch(ScriptDataSetRuntime.java:103)
       at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery.java:260)
       at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch(OdiAdapter.java:226)
       at org.eclipse.birt.data.engine.executor.cache.RowResultSet.fetch(RowResultSet.java:145)
       at org.eclipse.birt.data.engine.executor.cache.RowResultSet.doNext(RowResultSet.java:118)
       at org.eclipse.birt.data.engine.executor.cache.RowResultSet.next(RowResultSet.java:96)
       at org.eclipse.birt.data.engine.executor.cache.ExpandableRowResultSet.next(ExpandableRowResultSet.java:63)
       at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.populateData(SmartCacheHelper.java:318)
       at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.initInstance(SmartCacheHelper.java:285)
       at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.getResultSetCache(SmartCacheHelper.java:246)
       at org.eclipse.birt.data.engine.executor.cache.SmartCache.<init>(SmartCache.java:74)</init>
    <init>   at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.populateOdiResultSet(PassUtil.java:110)</init>
    <init>   at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.pass(PassUtil.java:62)</init>
    <init>   at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.doSinglePass(PassManager.java:170)</init>
    <init>   at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.prepareDataSetResultSet(PassManager.java:94)</init>
    <init>   at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.pass(PassManager.java:134)</init>
    <init>   at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.populateResultSet(PassManager.java:74)</init>
    <init>   at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.populateResultSet(ResultSetPopulator.java:218)</init>
    <init>   at org.eclipse.birt.data.engine.executor.transform.CachedResultSet.(CachedResultSet.java:200)</init>
    <init>   at org.eclipse.birt.data.engine.executor.CandidateQuery.execute(CandidateQuery.java:142)</init>
    <init>   at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:226)</init>
    <init>   at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1257)</init>
    <init>   at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:233)</init>
    <init>   at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:178)</init>
    <init>   at org.eclipse.birt.report.engine.data.dte.QueryResultSet.(QueryResultSet.java:98)</init>
    <init>   at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)</init>
    <init>   at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:83)</init>
    <init>   at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:286)</init>
    <init>   at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1954)</init>
    <init>   at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)</init>
    <init>   at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)</init>
    <init>   at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)</init>
    <init>   at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)</init>
    <init>   at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)</init>
    <init>   at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:258)</init>
    <init>   at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:273)</init>
    <init>   at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:89)</init>
    <init>   at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)</init>
    <init>   at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:159)</init>
    <init>   at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)</init>
    <init>   at org.eclipse.birt.report.service.actionhandler.BirtChangeParameterActionHandler.runReport(BirtChangeParameterActionHandler.java:58)</init>
    <init>   at org.eclipse.birt.report.service.actionhandler.AbstractChangeParameterActionHandler.__execute(AbstractChangeParameterActionHandler.java:52)</init>
    <init>   at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)</init>
    <init>   at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)</init>
    <init>   at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)</init>
    <init>   at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleChangeParameter(BirtDocumentProcessor.java:100)</init>
    <init>   at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:104)</init>
    <init>   at java.base/java.lang.reflect.Method.invoke(Method.java:578)</init>
    <init>   at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)</init>
    <init>   at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)</init>
    <init>   at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)</init>
    <init>   at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)</init>
    <init>   at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)</init>
    <init>   at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)</init>
    <init>   at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)</init>
    <init>   at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)</init>
    <init>   at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)</init>
    <init>   at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)</init>
    <init>   at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)</init>
    <init>   at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)</init>
    <init>   at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)</init>
    <init>   at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)</init>
    <init>   at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)</init>
    <init>   at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)</init>
    <init>   at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865)</init>
    <init>   at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1655)</init>
    <init>   at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)</init>
    <init>   at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1634)</init>
    <init>   at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:533)</init>
    <init>   at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)</init>
    <init>   at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)</init>
    <init>   at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)</init>
    <init>   at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)</init>
    <init>   at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)</init>
    <init>   at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)</init>
    <init>   at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)</init>
    <init>   at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)</init>
    <init>   at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)</init>
    <init>   at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)</init>
    <init>   at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)</init>
    <init>   at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)</init>
    <init>   at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)</init>
    <init>   at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:219)</init>
    <init>   at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)</init>
    <init>   at org.eclipse.jetty.server.Server.handle(Server.java:531)</init>
    <init>   at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352)</init>
    <init>   at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260)</init>
    <init>   at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281)</init>
    <init>   at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)</init>
    <init>   at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118)</init>
    <init>   at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)</init>
    <init>   at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)</init>
    <init>   at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)</init>
    <init>   at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)</init>
    <init>   at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)</init>
    <init>   at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:760)</init>
    <init>   at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:678)</init>
    <init>   at java.base/java.lang.Thread.run(Thread.java:1623)</init>
    <init>Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_FETCH(). Source:</init>
    <init>------</init>
    <init>" + if (!maximoDataSet.fetch())</init>
    <init>return (false);</init>
    <init>// Add a line for each output column</init>
    <init>// The specific get method should match the data type of the output column.</init>
    <init>row["textfield"] = maximoDataSet.getString("textfield"); </init>
    <init>row["datefield"] = maximoDataSet.getTimestamp("datefield"); </init>
    <init>return (true); + "</init>
    <init>-----</init>
    <init>A BIRT exception occurred. See next exception for more information.</init>
    <init>Wrapped com.ibm.db2.jcc.am.SqlSyntaxErrorException: DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=AS;SELECT w.WONUM ;AND, DRIVER=4.26.14 (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#1)</init>
    <init>   at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:147)</init>
    <init>   at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:90)</init>
    <init>... 106 more</init>
    <init>Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred. See next exception for more information.</init>
    <init>   at org.eclipse.birt.data.engine.core.DataException.wrap(DataException.java:123)</init>
    <init>   at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:1003)</init>
    <init>   at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:138)</init>
    <init>... 107 more</init>
    <init>Caused by: org.eclipse.birt.core.exception.CoreException: Wrapped com.ibm.db2.jcc.am.SqlSyntaxErrorException: DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=AS;SELECT w.WONUM ;AND, DRIVER=4.26.14 (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#1)</init>
    <init>   at org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoException(JavascriptEvalUtil.java:307)</init>
    <init>   at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:106)</init>
    <init>   at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScript(JavascriptEvalUtil.java:138)</init>
    <init>   at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:999)</init>
    <init>... 108 more</init>
    <init>Caused by: org.mozilla.javascript.WrappedException: Wrapped com.ibm.db2.jcc.am.SqlSyntaxErrorException: DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=AS;SELECT w.WONUM ;AND, DRIVER=4.26.14 (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#1)</init>
    <init>   at org.mozilla.javascript.Context.throwAsScriptRuntimeEx(Context.java:1754)</init>
    <init>   at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:148)</init>
    <init>   at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:225)</init>
    <init>   at org.mozilla.javascript.optimizer.OptRuntime.callProp0(OptRuntime.java:85)</init>
    <init>   at org.mozilla.javascript.gen._report_data_sets_script_data_set__id__5___method__name__fetch___16._c___bm_FETCH_1(/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]:1)</init>
    <init>   at org.mozilla.javascript.gen._report_data_sets_script_data_set__id__5___method__name__fetch___16.call(/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"])</init>
    <init>   at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:74)</init>
    <init>   at org.mozilla.javascript.gen._report_data_sets_script_data_set__id__5___method__name__fetch___17._c_script_0(/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]:0)</init>
    <init>   at org.mozilla.javascript.gen._report_data_sets_script_data_set__id__5___method__name__fetch___17.call(/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"])</init>
    <init>   at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)</init>
    <init>   at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3091)</init>
    <init>   at org.mozilla.javascript.gen._report_data_sets_script_data_set__id__5___method__name__fetch___17.exec(/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"])</init>
    <init>   at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:99)</init>
    <init>... 110 more</init>
    <init>Caused by: com.ibm.db2.jcc.am.SqlSyntaxErrorException: DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=AS;SELECT w.WONUM ;AND, DRIVER=4.26.14</init>
    <init>   at com.ibm.db2.jcc.am.b7.a(b7.java:810)</init>
    <init>   at com.ibm.db2.jcc.am.b7.a(b7.java:66)</init>
    <init>   at com.ibm.db2.jcc.am.b7.a(b7.java:140)</init>
    <init>   at com.ibm.db2.jcc.am.k4.c(k4.java:2824)</init>
    <init>   at com.ibm.db2.jcc.am.k4.d(k4.java:2808)</init>
    <init>   at com.ibm.db2.jcc.am.k4.a(k4.java:2234)</init>
    <init>   at com.ibm.db2.jcc.am.k5.a(k5.java:8242)</init>
    <init>   at com.ibm.db2.jcc.t4.ab.i(ab.java:206)</init>
    <init>   at com.ibm.db2.jcc.t4.ab.b(ab.java:96)</init>
    <init>   at com.ibm.db2.jcc.t4.p.a(p.java:32)</init>
    <init>   at com.ibm.db2.jcc.t4.av.i(av.java:150)</init>
    <init>   at com.ibm.db2.jcc.am.k4.al(k4.java:2203)</init>
    <init>   at com.ibm.db2.jcc.am.k5.bq(k5.java:3730)</init>
    <init>   at com.ibm.db2.jcc.am.k5.a(k5.java:4609)</init>
    <init>   at com.ibm.db2.jcc.am.k5.b(k5.java:4182)</init>
    <init>   at com.ibm.db2.jcc.am.k5.bd(k5.java:780)</init>
    <init>   at com.ibm.db2.jcc.am.k5.executeQuery(k5.java:745)</init>
    <init>   at com.ibm.tivoli.maximo.report.script.MXReportDataSetImpl.fetch(MXReportDataSetImpl.java:329)</init>
    <init>   at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:126)</init>
    <init>... 122 more</init>
    org.eclipse.birt.report.engine.api.EngineException: Data Set script method "Fetch" returned null; expected a Boolean value.
       at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:249)
       at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:238)
       at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:165)
    <init>Caused by: org.eclipse.birt.data.engine.core.DataException: Data Set script method "Fetch" returned null; expected a Boolean value.</init>
    <init>   at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:153)</init>
    <init><init><init>... 104 more</init></init></init>
    Philip Marrone
  • 4.  RE: BIRT 4.8 Error
    Posted 12-11-2023 12:01
    I would suggest making sure that your data fields, sql select statement  and fetch script all match.
     To me it looks like you haven't set up your fetch script yet.
    Bob Kraus
    Missouri S&T
  • 5.  RE: BIRT 4.8 Error
    Posted 12-11-2023 12:40
    Thank you Bob for the feedback. I have the following script written (see below), and this is my first report that I have attempted from scratch so I appreciate any advice you may offer.
    maximoDataSet = MXReportDataSetProvider.create(this.getDataSource().getName(), this.getName());
    maximoDataSet.open();
    var shopwhere = "1=1";
    if (params["shop"].value) {
      shopwhere += " AND " + MXReportSqlFormat.createParamWhereClause("shop.BCH_PARshop", params["shop"]);
    var datewhere = "1=1";
    datewhere += " AND week(w.TARGSTARTDATE) = (week(sysdate) - 1) AND year(w.SCHEDSTART) = year(sysdate)";
    if (params["startdate"].value) {
      datewhere += " AND w.TARGSTARTDATE >= " + MXReportSqlFormat.getStartDayTimestampFunction(params["startdate"]);
    if (params["enddate"].value) {
      datewhere += " AND w.TARGSTARTDATE <= " + MXReportSqlFormat.getEndDayTimestampFunction(params["enddate"]);
    var sqlText = "SELECT "
      + "w.WONUM AS 'Work Order', "
      + "PM.FREQUENCY AS 'Frequency', "
      + "PM.FREQUNIT AS 'Interval', "
      + "w.LOCATION AS 'ROOM', "
      + "TO_CHAR(w.SCHEDSTART, 'MM/DD/YY') AS 'Scheduled Start', "
      + "TO_CHAR(w.REPORTDATE, 'MM/DD/YY') AS 'Reported Date', "
      + "UPPER(w.DESCRIPTION) AS 'Description', "
      + "shop.BCH_PARshop AS 'Parent shop', "
      + "w.PERSONGROUP AS 'Shop', "
      + "w.ASSETNUM AS 'Equipment', "
      + "w.Status AS 'Status', "
      + "w.LEAD AS 'Assigned To', "
      + "pm.BCH_PMREG AS 'Compliance', "
      + "w.PMNUM AS 'PM', "
      + "shop.BCH_GRPLDR AS 'Group Leader', "
      + "shop.BCH_shopSUP AS 'Supervisor' "
      + "FROM WORKORDER AS w "
      + "LEFT JOIN MAXIMO.PM AS PM ON w.PMNUM = PM.PMNUM "
      + "LEFT JOIN Maximo.PERSONGROUP AS shop ON PM.PERSONGROUP = shop.PERSONGROUP "
      + "LEFT JOIN Maximo.WOSTATUS AS status ON w.WONUM = status.WONUM "
      + "WHERE PM.FREQUNIT = 'WEEKS' "
      + "AND w.status NOT IN ('COMP-TECH', 'COMP-SUPV','CLOSE','COMP','COMP-REVIEWED', 'CAN') "
      + "AND PM.BCH_PMREG = 'TJC' "
      + "AND w.TARGSTARTDATE BETWEEN DATE('2023-12-03') AND DATE('2023-12-09') "
      + "AND " + shopwhere + " "
      + "AND " + datewhere;
    maximoDataSet.setQuery(sqlText);
    What does the fetch script contain and where do I find it in the designer? (sorry) Please advise, thank you so much for your help so far.
    Philip Marrone
  • 6.  RE: BIRT 4.8 Error
    Posted 12-11-2023 13:42
    Select the Dataset on the left, then from the drop-down, select the fetch script.
    Then, make sure that the data fields from the Dataset are the same in the fetch script.
    Bob Kraus
    Missouri S&T
  • 7.  RE: BIRT 4.8 Error
    Posted 12-11-2023 15:44
    Thank you Bob, I am working on this now and will update the thread with my progess. You have been very helpful, I greatly appreciate your efforts on my behalf.
    Philip Marrone
  • 8.  RE: BIRT 4.8 Error
    Posted 12-11-2023 16:13
    Hi Bob,
    I weorked on the fetch script and received the following error, I am unsure how to proceed:
    org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "maximoDataSet = MXReportDataSetProvider.create(this.getDataSource().getName(), this.getName());
    + "w.WONUM, "
    + "PM.FREQUENCY, "
    + "PM.FREQUNIT, "
    + "TO_CHAR(w.SCHEDSTART, 'MM/DD/YY'), "
    + "TO_CHAR(w.REPORTDATE, 'MM/DD/YY')', "
    + "UPPER(w.DESCRIPTION), "
    + "shop.BCH_PARshop', "
    + "w.PERSONGROUP, "
    + "w.ASSETNUM
    + "w.LEAD', "
    + "pm.BCH_PMREG, "
    + "w.PMNUM, "
    + "shop.BCH_GRPLDR', "
    + "shop.BCH_shopSUP' "
    maximoDataSet.setQuery(sqlText);":
    Fail to execute script in function __bm_OPEN(). Source:
    " + maximoDataSet = MXReportDataSetProvider.create(this.getDataSource().getName(), this.getName());
    + "w.WONUM, "
    + "PM.FREQUENCY, "
    + "PM.FREQUNIT, "
    + "w.PERSONGROUP, "
    + "w.ASSETNUM
    + "w.LEAD', "
    + "pm.BCH_PMREG, "
    + "w.PMNUM, "
    maximoDataSet.setQuery(sqlText); + "
    unterminated string literal (/report/data-sets/script-data-set[@id="5"]/method[@name="open"]#27).
       at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:98)
       at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open(ScriptDataSetRuntime.java:80)
       at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.java:247)
       at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:223)
       at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)</init>
    <init>Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_OPEN(). Source:</init>
    <init>------</init>
    <init>" + maximoDataSet = MXReportDataSetProvider.create(this.getDataSource().getName(), this.getName());</init>
    <init>maximoDataSet.open();</init>
    <init>var shopwhere = "1=1";</init>
    <init>if (params["shop"].value) {</init>
    <init>shopwhere += " AND " + MXReportSqlFormat.createParamWhereClause("shop.BCH_PARshop", params["shop"]);</init>
    <init>}</init>
    <init>var datewhere = "1=1";</init>
    <init>datewhere += " AND week(w.TARGSTARTDATE) = (week(sysdate) - 1) AND year(w.SCHEDSTART) = year(sysdate)";</init>
    <init>if (params["startdate"].value) {</init>
    <init>datewhere += " AND w.TARGSTARTDATE >= " + MXReportSqlFormat.getStartDayTimestampFunction(params["startdate"]);</init>
    <init>}</init>
    <init>if (params["enddate"].value) {</init>
    <init>datewhere += " AND w.TARGSTARTDATE <= " + MXReportSqlFormat.getEndDayTimestampFunction(params["enddate"]);</init>
    <init>}</init>
    <init>var sqlText = "SELECT "</init>
    <init>+ "w.WONUM, "</init>
    <init>+ "PM.FREQUENCY, "</init>
    <init>+ "PM.FREQUNIT, "</init>
    <init>+ "TO_CHAR(w.SCHEDSTART, 'MM/DD/YY'), "</init>
    <init>+ "TO_CHAR(w.REPORTDATE, 'MM/DD/YY')', "</init>
    <init>+ "UPPER(w.DESCRIPTION), "</init>
    <init>+ "shop.BCH_PARshop', "</init>
    <init>+ "w.PERSONGROUP, "</init>
    <init>+ "w.ASSETNUM</init>
    <init>+ "w.LEAD', "</init>
    <init>+ "pm.BCH_PMREG, "</init>
    <init>+ "w.PMNUM, "</init>
    <init>+ "shop.BCH_GRPLDR', "</init>
    <init>+ "shop.BCH_shopSUP' "</init>
    <init>+ "FROM WORKORDER AS w "</init>
    <init>+ "LEFT JOIN MAXIMO.PM AS PM ON w.PMNUM = PM.PMNUM "</init>
    <init>+ "LEFT JOIN Maximo.PERSONGROUP AS shop ON PM.PERSONGROUP = shop.PERSONGROUP "</init>
    <init>+ "LEFT JOIN Maximo.WOSTATUS AS status ON w.WONUM = status.WONUM "</init>
    <init>+ "WHERE PM.FREQUNIT = 'WEEKS' "</init>
    <init>+ "AND w.status NOT IN ('COMP-TECH', 'COMP-SUPV','CLOSE','COMP','COMP-REVIEWED', 'CAN') "</init>
    <init>+ "AND PM.BCH_PMREG = 'TJC' "</init>
    <init>+ "AND w.TARGSTARTDATE BETWEEN DATE('2023-12-03') AND DATE('2023-12-09') "</init>
    <init>+ "AND " + shopwhere + " "</init>
    <init>+ "AND " + datewhere;</init>
    <init>maximoDataSet.setQuery(sqlText); + "</init>
    <init>-----</init>
    <init>unterminated string literal (/report/data-sets/script-data-set[@id="5"]/method[@name="open"]#27)</init>
    <init>... 88 more</init>
    <init>   at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:128)</init>
    <init>... 89 more</init>
    <init>Caused by: org.eclipse.birt.core.exception.CoreException: unterminated string literal (/report/data-sets/script-data-set[@id="5"]/method[@name="open"]#27)</init>
    <init>... 90 more</init>
    <init>Caused by: org.mozilla.javascript.EvaluatorException: unterminated string literal (/report/data-sets/script-data-set[@id="5"]/method[@name="open"]#27)</init>
    <init>   at org.mozilla.javascript.DefaultErrorReporter.runtimeError(DefaultErrorReporter.java:77)</init>
    <init>   at org.mozilla.javascript.DefaultErrorReporter.error(DefaultErrorReporter.java:64)</init>
    <init>   at org.mozilla.javascript.Parser.addError(Parser.java:188)</init>
    <init>   at org.mozilla.javascript.Parser.addError(Parser.java:166)</init>
    <init>   at org.mozilla.javascript.Parser.addError(Parser.java:162)</init>
    <init>   at org.mozilla.javascript.TokenStream.getToken(TokenStream.java:516)</init>
    <init>   at org.mozilla.javascript.Parser.peekToken(Parser.java:296)</init>
    <init>   at org.mozilla.javascript.Parser.unaryExpr(Parser.java:2249)</init>
    <init>   at org.mozilla.javascript.Parser.mulExpr(Parser.java:2229)</init>
    <init>   at org.mozilla.javascript.Parser.addExpr(Parser.java:2218)</init>
    <init>   at org.mozilla.javascript.Parser.shiftExpr(Parser.java:2194)</init>
    <init>   at org.mozilla.javascript.Parser.relExpr(Parser.java:2169)</init>
    <init>   at org.mozilla.javascript.Parser.eqExpr(Parser.java:2141)</init>
    <init>   at org.mozilla.javascript.Parser.bitAndExpr(Parser.java:2130)</init>
    <init>   at org.mozilla.javascript.Parser.bitXorExpr(Parser.java:2119)</init>
    <init>   at org.mozilla.javascript.Parser.bitOrExpr(Parser.java:2108)</init>
    <init>   at org.mozilla.javascript.Parser.andExpr(Parser.java:2097)</init>
    <init>   at org.mozilla.javascript.Parser.orExpr(Parser.java:2086)</init>
    <init>   at org.mozilla.javascript.Parser.condExpr(Parser.java:2062)</init>
    <init>   at org.mozilla.javascript.Parser.assignExpr(Parser.java:2033)</init>
    <init>   at org.mozilla.javascript.Parser.variables(Parser.java:1870)</init>
    <init>   at org.mozilla.javascript.Parser.statementHelper(Parser.java:986)</init>
    <init>   at org.mozilla.javascript.Parser.statement(Parser.java:901)</init>
    <init>   at org.mozilla.javascript.Parser.parseFunctionBody(Parser.java:634)</init>
    <init>   at org.mozilla.javascript.Parser.function(Parser.java:795)</init>
    <init>   at org.mozilla.javascript.Parser.parse(Parser.java:533)</init>
    <init>   at org.mozilla.javascript.Parser.parse(Parser.java:478)</init>
    <init>   at org.mozilla.javascript.Context.compileImpl(Context.java:2348)</init>
    <init>   at org.mozilla.javascript.Context.compileString(Context.java:1335)</init>
    <init>   at org.mozilla.javascript.Context.compileString(Context.java:1324)</init>
    <init>   at org.eclipse.birt.core.script.JavascriptEvalUtil.getCompiledScript(JavascriptEvalUtil.java:156)</init>
    <init>   at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:95)</init>
    <init>... 92 more</init>
    return (false);
    row["WONUM"] = maximoDataSet.getInteger("WONUM");
    row["STATUS"] = maximoDataSet.getString("STATUS");
    row["SCHEDSTART"] = maximoDataSet.getDateTime("SCHEDSTART");
    row["FREQUENCY"] = maximoDataSet.getDecimal("FREQUENCY");
    row["FREQUNIT"] = maximoDataSet.getString("FREQUNIT");
    row["LOCATION"] = maximoDataSet.getString("LOCATION");
    row["DESCRIPTION"] = maximoDataSet.getString("DESCRIPTION");
    row["BCH_PARSHOP"] = maximoDataSet.getString("BCH_PARSHOP");
    row["ASSETNUM"] = maximoDataSet.getString("ASSETNUM");
    row["LEAD"] = maximoDataSet.getString("LEAD");
    row["BCH_PMREG"] = maximoDataSet.getString("BCH_PMREG");
    row["PMNUM"] = maximoDataSet.getString("PMNUM");
    row["BCH_GRPLDR"] = maximoDataSet.getString("BCH_GRPLDR");
    row["BCH_SHOPSUP"] = maximoDataSet.getString("BCH_SHOPSUP");
    row["REPORTDATE"] = maximoDataSet.getDateTime("REPORTDATE");
    return (true);":
    return (false);
    return (true); + "
    ReferenceError: "maximoDataSet" is not defined. (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#1).
    <init>------</init>
    <init>row["WONUM"] = maximoDataSet.getInteger("WONUM"); </init>
    <init>row["STATUS"] = maximoDataSet.getString("STATUS");</init>
    <init>row["SCHEDSTART"] = maximoDataSet.getDateTime("SCHEDSTART"); </init>
    <init>row["FREQUENCY"] = maximoDataSet.getDecimal("FREQUENCY");</init>
    <init>row["FREQUNIT"] = maximoDataSet.getString("FREQUNIT");</init>
    <init>row["LOCATION"] = maximoDataSet.getString("LOCATION"); </init>
    <init>row["DESCRIPTION"] = maximoDataSet.getString("DESCRIPTION");</init>
    <init>row["BCH_PARSHOP"] = maximoDataSet.getString("BCH_PARSHOP"); </init>
    <init>row["ASSETNUM"] = maximoDataSet.getString("ASSETNUM");</init>
    <init>row["LEAD"] = maximoDataSet.getString("LEAD");</init>
    <init>row["BCH_PMREG"] = maximoDataSet.getString("BCH_PMREG"); </init>
    <init>row["PMNUM"] = maximoDataSet.getString("PMNUM");</init>
    <init>row["BCH_GRPLDR"] = maximoDataSet.getString("BCH_GRPLDR"); </init>
    <init>row["BCH_SHOPSUP"] = maximoDataSet.getString("BCH_SHOPSUP");</init>
    <init>row["REPORTDATE"] = maximoDataSet.getDateTime("REPORTDATE");</init>
    <init>-----</init>
    <init>ReferenceError: "maximoDataSet" is not defined. (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#1)</init>
    <init>Caused by: org.eclipse.birt.core.exception.CoreException: ReferenceError: "maximoDataSet" is not defined. (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#1)</init>
    <init>Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "maximoDataSet" is not defined. (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#1)</init>
    <init>   at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3687)</init>
    <init>   at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3665)</init>
    <init>   at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3750)</init>
    <init>   at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1794)</init>
    <init>   at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1733)</init>
    <init>   at org.mozilla.javascript.gen._report_data_sets_script_data_set__id__5___method__name__fetch___60._c___bm_FETCH_1(/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]:1)</init>
    <init>   at org.mozilla.javascript.gen._report_data_sets_script_data_set__id__5___method__name__fetch___60.call(/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"])</init>
    org.eclipse.birt.report.engine.api.EngineException: Column binding "Work Order" has referred to a data set column "Work Order" which does not exist.
       at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1252)
       at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1231)
       at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
    Caused by: org.eclipse.birt.data.engine.core.DataException: Column binding "Work Order" has referred to a data set column "Work Order" which does not exist.
       at org.eclipse.birt.data.engine.impl.ResultIterator.validateManualBindingExpressions(ResultIterator.java:380)
       at org.eclipse.birt.data.engine.impl.ResultIterator.<init>(ResultIterator.java:148)</init>
    <init>   at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:222)</init>
    <init><init>... 74 more</init></init>
    Philip Marrone
  • 9.  RE: BIRT 4.8 Error
    Posted 12-11-2023 16:22
    Fix your Select statement. I see missing commas and extra single quotes here and there.
    shop.BCH_PARshop',
     w.ASSETNUM
    w.LEAD',
    shop.BCH_GRPLDR',
    etc.
    Bob Kraus
    Missouri S&T
  • 10.  RE: BIRT 4.8 Error
    Posted 12-11-2023 16:41
    Thank you. I fixed that and received an error: "org.eclipse.birt.report.engine.api.EngineException: Column binding "Work Order" has referred to a data set column "Work Order" which does not exist,'"
    I only reference WONUM in the report and not "Work Order". For reference, here are my layout, output columns, parameters, and fetch script.
    return (false);
    return (true);
    Philip Marrone
  • 11.  RE: BIRT 4.8 Error
    Posted 12-12-2023 09:07
    Show me your Data Set
    Bob Kraus
    Senior Business Services Consultant  |  Facilities Services  |  Missouri S&T
    General Services Bldg, 1701 Spruce Dr, Rolla, MO 65409
    Email: krausr@mst.edu   Phone: 573-341-7288   Site: facilitiesoperations.mst.edu
    Missouri S&T - Solving For Tomorrow
    Social: YouTube
  • 12.  RE: BIRT 4.8 Error
    Posted 12-12-2023 09:51
    Sure thing. Here is my data set. Below, I believe I found the culprit in the maintable, although I do not know how to remove it.
    Please see the below where I believe I may have found the issue:
    Philip Marrone
  • 13.  RE: BIRT 4.8 Error
    Posted 12-12-2023 10:02
    Go to the Layout Tab.
    Click the corner of the layout and click on Table (not Grid)
    Click on the Binding Tab. Here you can add, remove etc.
    Bob Kraus
    Social: YouTube
  • 14.  RE: BIRT 4.8 Error
    Posted 12-12-2023 11:25
    Thank you, good sir. I have gotten further than before, but the report comes up blank:
    I thought perhaps that something was wrong with my column bindings, but from my limited knowledge they appear to be okay:
    Fetch script, just incase it is relevant here:
    Philip Marrone
  • 15.  RE: BIRT 4.8 Error
    Posted 12-12-2023 11:35
    If your result comes up blank without any errors, recheck your SQL select statement.
    Can you clean it and run it in SQL to see what the number of records should be?
    Bob Kraus
    Social: YouTube
  • 16.  RE: BIRT 4.8 Error
    Posted 12-12-2023 11:53
    Hello again,
    I ran in SQL and get 25 records. However, when I went back to run it again it runs as though the fetch script is null, even though I have not changed anything since the last time testing the report. Fetch script is still as I captured above (when it did work), and now I get the following stack trace error:
    return (false);
    return (true);":
    return (false);
    return (true); + "
    Wrapped com.ibm.tivoli.maximo.report.script.MXReportRuntimeException: com.ibm.db2.jcc.am.SqlException: [jcc][10150][10300][4.26.14] Invalid parameter: Unknown column name STATUS. ERRORCODE=-4460, SQLSTATE=null (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#7).
    <init>------</init>
    <init>-----</init>
    <init>Wrapped com.ibm.tivoli.maximo.report.script.MXReportRuntimeException: com.ibm.db2.jcc.am.SqlException: [jcc][10150][10300][4.26.14] Invalid parameter: Unknown column name STATUS. ERRORCODE=-4460, SQLSTATE=null (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#7)</init>
    <init>Caused by: org.eclipse.birt.core.exception.CoreException: Wrapped com.ibm.tivoli.maximo.report.script.MXReportRuntimeException: com.ibm.db2.jcc.am.SqlException: [jcc][10150][10300][4.26.14] Invalid parameter: Unknown column name STATUS. ERRORCODE=-4460, SQLSTATE=null (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#7)</init>
    <init>Caused by: org.mozilla.javascript.WrappedException: Wrapped com.ibm.tivoli.maximo.report.script.MXReportRuntimeException: com.ibm.db2.jcc.am.SqlException: [jcc][10150][10300][4.26.14] Invalid parameter: Unknown column name STATUS. ERRORCODE=-4460, SQLSTATE=null (/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]#7)</init>
    <init>   at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:32)</init>
    <init>   at org.mozilla.javascript.gen._report_data_sets_script_data_set__id__5___method__name__fetch___60._c___bm_FETCH_1(/report/data-sets/script-data-set[@id="5"]/method[@name="fetch"]:7)</init>
    <init>Caused by: com.ibm.tivoli.maximo.report.script.MXReportRuntimeException: com.ibm.db2.jcc.am.SqlException: [jcc][10150][10300][4.26.14] Invalid parameter: Unknown column name STATUS. ERRORCODE=-4460, SQLSTATE=null</init>
    <init>   at com.ibm.tivoli.maximo.report.script.MXReportDataSetImpl.getString(MXReportDataSetImpl.java:456)</init>
    <init>Caused by: com.ibm.db2.jcc.am.SqlException: [jcc][10150][10300][4.26.14] Invalid parameter: Unknown column name STATUS. ERRORCODE=-4460, SQLSTATE=null</init>
    <init>   at com.ibm.db2.jcc.am.b7.a(b7.java:794)</init>
    <init>   at com.ibm.db2.jcc.am.b7.a(b7.java:116)</init>
    <init>   at com.ibm.db2.jcc.am.ao.a(ao.java:2139)</init>
    <init>   at com.ibm.db2.jcc.am.ResultSet.findColumnX(ResultSet.java:2076)</init>
    <init>   at com.ibm.db2.jcc.am.ResultSet.getString(ResultSet.java:1787)</init>
    <init>   at com.ibm.tivoli.maximo.report.script.MXReportResultSet.getString(MXReportResultSet.java:541)</init>
    <init>   at com.ibm.tivoli.maximo.report.script.MXReportDataSetImpl.getString(MXReportDataSetImpl.java:438)</init>
    <init>... 125 more</init>
    return (false);
    return (true);":
    return (false);
    return (true); + "
    <init>   at org.eclipse.birt.report.engine.data.dte.QueryResultSet.(QueryResultSet.java:115)</init>
    <init>   at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:176)</init>
    <init>   at org.eclipse.birt.report.engine.executor.DataItemExecutor.execute(DataItemExecutor.java:75)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.execute(HTMLAbstractLM.java:468)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.execute(HTMLAbstractLM.java:476)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM.intializeHeaderContent(HTMLListingBandLM.java:98)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM.initialize(HTMLListingBandLM.java:50)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.initialize(HTMLTableBandLM.java:44)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLLayoutManagerFactory.createLayoutManager(HTMLLayoutManagerFactory.java:40)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.createLayoutManager(HTMLReportLayoutEngine.java:138)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:68)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLRepeatHeaderLM.layoutChildren(HTMLRepeatHeaderLM.java:46)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:71)</init>
    <init>------</init>
    <init>-----</init>
    <init>... 121 more</init>
    <init>... 123 more</init>
    <init>... 137 more</init>
    <init>... 140 more</init>
    <init>... 119 more</init>
    return (false);
    return (true);":
    return (false);
    return (true); + "
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)</init>
    <init>   at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)</init>
    <init>------</init>
    <init>-----</init>
    <init>... 132 more</init>
    <init>... 133 more</init>
    <init>... 134 more</init>
    <init>... 136 more</init>
    <init>... 148 more</init>
    <init>... 151 more</init>
    <init><init><init>... 130 more</init></init></init>
    Philip Marrone
  • 17.  RE: BIRT 4.8 Error
    Posted 12-12-2023 12:21
    WONUM is not GetInteger, it is GetString.
    Bob Kraus
    Social: YouTube
  • 18.  RE: BIRT 4.8 Error
    Posted 12-12-2023 12:36
    Alright, thanks once again for your help. I can consistently get it to run now but unfortunately without any results. As I said there should be 25 results.
    Philip Marrone
  • 19.  RE: BIRT 4.8 Error
    Posted 12-12-2023 13:04
    I know that BIRT plays a little differently than SQL.
    You might try:
    1. Instead of assigning an alias to the tables (w.wonum) use the full name (workorder.wonum)
    2. Try using '01-JAN-23' instead of '2023-01-01' for dates
    3. Try LEFT OUTER JOIN instead of LEFT JOIN
    Bob Kraus
    Social: YouTube
  • 20.  RE: BIRT 4.8 Error
    Posted 12-12-2023 13:39
    I tried this and updated the above. I am not sure. When I did my fetch script, I noticed that there is also an "OnFetch", is that something I need to develop also? Just thinking what I might be doing wrong. Thanks so much for your help thus far.
    Philip Marrone
  • 21.  RE: BIRT 4.8 Error
    Posted 12-12-2023 14:33
    That's about all I know.
    Good Luck.
    Bob Kraus
    Social: YouTube
  • 22.  RE: BIRT 4.8 Error
    Posted 12-12-2023 15:32
    Thanks for all of your help, it got me this far and is much appreciated.
    Philip Marrone
  • 23.  RE: BIRT 4.8 Error
    Posted 12-13-2023 08:46
    Hi Phil,
    Did you get this report working?  Or are you still receiving the following error?
    If you are receiving the error or blank data you may want to check your SQL at:
    The problem may be your label of status.  That is a valid column name in the workorder table and may not be able to be used as a label for WOSTATUS.
    Jim Robb
    Axient
  • 24.  RE: BIRT 4.8 Error
    Posted 01-12-2024 17:44
    what does your dataset fetch look like?
    I am guessing you need to comment those two lines out or remove then.
    Wes Williams
    Northrop Grumman
  • 25.  RE: BIRT 4.8 Error
    Posted 12-13-2023 17:56
    Hi Phillip
    Firstly, have you read all of the Maximo76_Designer431_Report 20Development Guide_Rev8.pdf?
    So, let's review.  There is an open is where the SQL to pulls the data from the database. Then the fetch is to map the SQL columns into the report columns.  Then you need to map those column outputs to the column in BIRT making sure that you assign the correct BIRT data type i.e. a wonum is string not integer.  Then on the layout you take the mapped column onto the layout.  Seems simple and seems like your doing the same thing three times.
    Also, I didn't get an impression whether you've embedded a debug statement like below as the SQL supplied is either from the code or a SQL tool rather than the output.
    Dates
    Please check out Section 6 fro discussion about dates.  I'd also suggest that you look at other reports that also use data parameters such as the Asset Availability report.  This is a much better way for self education.
    Firstly, ensure that you have defined the parameter date Data type=date
    Then in the open, you need to convert the date parameters into the JDBC format.  An example is from the Asset Availability report
    startdt_jdbc = MXReportSqlFormat.getDateFunction(params["startdate"]);
    startdt = params["startdate"];
    enddt_jdbc = MXReportSqlFormat.getDateFunction(params["enddate"]);
    enddt = params["enddate"];
    and this is the altered SQL in the Open
    + " and workperiod.workdate between " + startdt_jdbc + " and " + enddt_jdbc
    I hope that this helps.
    ISW
    Maximo Practice Manager
    eMail: ckokay@isw.net.au
    Phone: +61-411-682-040
    #IBMChampion2023
