  • 1.  Monthly PM Due Dates
    Posted 05-19-2026 10:27
    For our PM's that run monthly, our requirement is to allow the full month for it to be completed regardless of how many days are in the month. All of them start on the first of the month. But the due dates vary. So in February they would be due on the 28th, March due the 31st, etc. The issue is that job plans have fixed durations and can't take into account the length of a given month. We aren't very strict on when they get it done, just as long as it was done sometime during the current month. Is there any way Maximo can be setup to work like this?
    Jason Johnson
    RSI
  • 2.  RE: Monthly PM Due Dates
    Posted 05-19-2026 13:24
    Hi Jason,
    As far as I know, Maximo does not support 'Calendar Month' logic the way you have described it for PMs. However, depend on how you run your PMs you could develop a Escalation or Automation Script that runs after your PMs run. For example if you us Automated PMWOGEN and it runs once a month at 2am and typically runs for 1 hour, you could then have an escalation or automation script that runs at 3:30am that would run to update the duedate as you have suggested.
    I am no expert at writing Escalations or Automation Scripts, but you could look at WOs that are PM worktype, with a report date of that day, with a PM frequency of Monthly, that updates the duedate to the last day of the month.
    This would be tricky to get correct and to ensure it runs at the right time. I would certainly test this out in a non-production environment so you do not mess up any WOs you currently have.
    Allan Henle
  • 3.  RE: Monthly PM Due Dates
    Posted 05-19-2026 18:49
    Jason,
    Here is an article on how to set the PMs based on your requirement in Maximo 7.6: https://www.ibm.com/support/pages/schedule-preventive-maintenance-work-order-last-day-month?view=full
    In Maximo Application Suite there is a system property to force due dates to end of calendar month: mxe.pm.enforceMaximumDayOfMonthContinuity
    Russ Mokrouz
    ABSG Consulting Inc.
  • 4.  RE: Monthly PM Due Dates
    Posted 05-20-2026 09:04
    Edited by Jason Johnson 05-21-2026 09:21
    Thank you Allan and Russ. We'll evaluate both of these methods. Much appreciated :D
    Jason Johnson
    RSI
  • 5.  RE: Monthly PM Due Dates
    Posted 05-20-2026 20:18
    Hi Jason
    I have just seen this and have another suggestion
    Each PM has two fields Start no earlier than and finish no later than
    if you add say 720 hours in the finish no later than field this converts close to the last day of the month  and you can then use this field to report which PM workorders were completed within the period
    This avoids the use of scripts etc and just changes the field which you use for your KPI's
    Regards
    Geoff Stokes
