  • 1.  IssueCurrentItem Dialog in Showing Lastcost
    Posted 06-08-2022 08:25
      |   view attached
    I added a field to the ISSUECURRENTITEM dialog window. I want to show the last cost value in the invcost table in this field. For this, I created a relationship in the ISSUECURRENTITEM table.
    Relationship name:  LASTCOST
    Relation:itemnum = :itemnum and location=:location and siteid=:siteid
    I set the attribute as LASTCOST.LASTCOST on the dialog screen.
    But it doesn't show lastcost value?
    Attached is a picture of the lastcost.
    Can you help with the matter?
    Aliriza Canakci
    Is Merkezleri Yönetim ve İşletim A.S
  • 2.  RE: IssueCurrentItem Dialog in Showing Lastcost
    Posted 06-08-2022 10:22
    Try using below expression
    lastcost in (select max(lastcost) from lastcost where itemnum = :itemnum and location=:location and siteid=:siteid)
    PAVAN KUMAR
    Maximo Consultant
  • 3.  RE: IssueCurrentItem Dialog in Showing Lastcost
    Posted 06-08-2022 10:56
    Hello ,
    Thank you for your support Pavan.
    I tried what you said. The relation name is Lastcost.Lastcost value is in the invcost table. I corrected the relation accordingly, but the data is not show.
    I created the relationship in the ISSUECURRENTITEM table.Where am I doing wrong?
    invcost in (select max(lastcost) from invcost where itemnum = :itemnum and location=:location and siteid=:siteid)
    Aliriza Canakci
  • 4.  RE: IssueCurrentItem Dialog in Showing Lastcost
    Posted 06-08-2022 11:52
    Hello Paven,
    Thank you for your support.
    The parent is ISSUCURRENTITEM table.The child is INVCOST table.The lastcost field in INVCOST.
    I want to show the field at the stock output in the ISSUE dialog window inside the INVENTOR application.
    Attached are the pictures.
    Aliriza Canakci
  • 5.  RE: IssueCurrentItem Dialog in Showing Lastcost
    Posted 06-08-2022 13:17
    It should get the output as per your requirement. I has tried the query in squirrel it showing the lastcost
    PAVAN KUMAR
    Maximo Consultant
  • 6.  RE: IssueCurrentItem Dialog in Showing Lastcost
    Posted 06-08-2022 13:20
    Small change has been done, Now you can try this, I guess it will work fine.
    lastcost in (select max(lastcost) from invcost where itemnum = :itemnum and itemsetid=:itemsetid and location=:storeloc and siteid=:siteid)
    PAVAN KUMAR
    Maximo Consultant
  • 7.  RE: IssueCurrentItem Dialog in Showing Lastcost
    Posted 06-08-2022 16:06
    You want to display the latest lastcost . if my understanding is right, then try below relation ship
    LASTCOST in (select max(LASTCOST ) from LASTCOST where itemnum = :itemnum and location=:location and siteid=:siteid)
    pavan Kumar
    Envision enterprise solutions
