  • 1.  Longdescription on ROUTESTOP.DESCRIPTION
    Posted 01-20-2025 11:25
    Hi!
    In our MAS 9 migration project we need to add longdescription on routestop descriptions.
    What is the easiest solution to fix this?
    Wonder if longdescription on jobtask has been removed from earlier versions of Maximo? (5.x or 6.x)
    I Checked the  longdescriptiontable where ldownertable = 'jobtask' and ldownercol = 'Description' and got over 50000 records.
    So it seems to the function was there before 2011-2012
    HENRIK SÖDER
    Quale Consulting AB
  • 2.  RE: Longdescription on ROUTESTOP.DESCRIPTION
    Posted 01-21-2025 17:19
    Hi Henrik
    Quick answer = It's still there in MAS 9.
    it should not have been removed due to the upgrade.  Please check if there is still JOBTASK.HASLD and JOBTASK.DESCRTION_LONGDESCRIPTION.  If yes, then most likely its a screen thing
    Principal Consultant
    COSOL
    #IBMChampion
  • 3.  RE: Longdescription on ROUTESTOP.DESCRIPTION
    Posted 01-22-2025 08:27
    My bad! I mixed up ROUTESTOPS and JOBTASK!
    Question is regarding Routestops. Jobtasks is OK longdescription is there but on routestops I don't have HASLD in routestop table.
    HENRIK SÖDER
    Quale Consulting AB
  • 4.  RE: Longdescription on ROUTESTOP.DESCRIPTION
    Posted 01-22-2025 17:56
    Hi Henrik
    There is a description field on the route stop, but without a long description.  I can't remember if that ever had a long description.  The route stop description will be come either the child work order description, the multiassetlocci description, or the task description depending on what option you have selected for the stop.
    COSOL
    #IBMChampion
Featured Podcast
Watch the Podcast
Watch the latest episode
