Set the response code in custom script handler
  • 1.  Set the response code in custom script handler
    Posted 10-21-2024 09:33
    I was going through this feature called custom script handler in Maximo.
    Invoking script through Automation Script Handler
    Ibm-maximo-dev remove preview
    Learn Anamitra's wisdom about Autoscripting
    View this on Ibm-maximo-dev >
    It allows us to call a script using a url either (POST or GET or UPDATE) and we can do our processing and return the responseBody.
    Apart from returning the responseBody can we return a response Code (e.g. 200, 400 or 500 etc) as well ?
    Rana Ahmed
    Maximomize
  • 2.  RE: Set the response code in custom script handler
    Posted 10-21-2024 14:54
    Unfortunately, no but this would be a good enhancement request. You can request the enhancement here: https://ibm-ai-apps.ideas.ibm.com/ideas/
  • 3.  RE: Set the response code in custom script handler
    Posted 10-21-2024 15:41
    Added it here. It would be great if others can up vote it
    Let us return response | IBM Sustainability Software - Ideas Portal
    Rana Ahmed
    Maximomize
  • 4.  RE: Set the response code in custom script handler
    Posted 10-22-2024 08:36
    I had a similar requirement but ended up doing it a different way. Voted for your idea.
    Manu Maganti
    EMA, Inc
  • 5.  RE: Set the response code in custom script handler
    Posted 10-22-2024 09:54
    Hi Manu,
    Thanks for the vote.
    What was the path you took for it?
    Rana Ahmed
    Maximomize
  • 6.  RE: Set the response code in custom script handler
    Posted 10-22-2024 09:59
    The external system was able to use status 500 with the specific status code appended at the end of each message.
    MM
  • 7.  RE: Set the response code in custom script handler
    Posted 10-23-2024 16:40
    Do you know any documentation for this
    Rana Ahmed
    Maximomize
  • 8.  RE: Set the response code in custom script handler
    Posted 10-23-2024 16:53
    We did it the "easy" way. If you have specific errors that are being sent back, you'll have the BMXAA ID referenced. We had a limited set that were being returned and what specific status code they were expecting. We just appended that to the end of the error text. Find out if your external system can extract the text at the end of the error message you're sending to identify the status code. Note that this was only for errors being returned as 500. They were ok with the other standard codes - 200, 400+, etc.
    MM
  • 9.  RE: Set the response code in custom script handler
    Best Answer
    Posted 10-24-2024 10:48
    You can do this like so:
    response = request.getHttpServletResponse();
    response.setStatus(302) # Set whatever status code you want.
    response.flushBuffer()
    The key to this is that by calling flushBuffer() on the HttpServletResponse you are flushing the header and response values to the client and preventing Maximo from overriding the values you have set.
    Let me know if you have any other questions about this.
    Jason
    Jason VenHuizen
    Sharptree
  • 10.  RE: Set the response code in custom script handler
    Posted 10-24-2024 10:54
    Very cool. Is this 'new' functionality? I'd asked IBM about this about 5 years ago, and they said it would involve java customization which was not acceptable to the client at that time.
    Thanks for this, Jason.
    M
    MM
  • 11.  RE: Set the response code in custom script handler
    Posted 10-24-2024 11:01
    No, this has always been part of the HttpServletResponse API.  It does have some potential risks in that it any additional headers or other information that IBM may add from being added to the response.  But in practice I have not seen this be an issue in the use cases I have encountered.
    Jason
  • 12.  RE: Set the response code in custom script handler
    Posted 10-30-2024 09:08
    That's brilliant and it is working.
    Rana Ahmed
    Maximomize
  • 13.  RE: Set the response code in custom script handler
    Posted 07-21-2025 10:28
    I tried this from a jython automation script (after modifying the Javascript code for the Python syntax), and it didn't work. Has anyone had this work in a jython script?
    Theo Pozzy
    OneGas
