  • 1.  Changing attributes on Parent/Child Workorders that are created from PM with route
    Posted 07-06-2026 14:16
    I am in need to set some attributes/fields on Parent/Child Workorders that are created from PM with route. I am able to do so on Parent WOs by the below mentioned automation script. However, I am not able to fetch child WOs in the same script. I have tried using in-built relationship or even MXSERVER but none worked.
    The launch point is Object based on WORKODER with SAVE Event (Add, Before Save). Please let me know how can I fetch child WOs.
    pmnum = mbo.getString("PMNUM")
    siteid = mbo.getString("SITEID")
    wonum = mbo.getString("WONUM")
    projectId = "0"
    userInfo = mxServer.getSystemUserInfo()
    if pmnum:
    # 2. Fetch the parent PM record using the PMNUM relationship or a MboSet
    # pmSet = mbo.getMboSet("$GET_PARENT_PM", "PM", "pmnum = :pmnum and siteid = :siteid")
    pmSet = mbo.getMboSet("PM")
    pmMbo = pmSet.moveFirst()
    if pmMbo:
    # 3. Retrieve value from PM field
    projectId = pmMbo.getString("MSD_PROJECT")
    # 4. Copy value to the Work Order field
    mbo.setValue("MSD_PROJECT", projectId)
    childSet = mxServer.getMboSet("WORKORDER", userInfo)
    childSet.setWhere("parent = :wonum and siteid=:siteid")
    childSet.reset()
    childMbo = childSet.moveFirst()
    while childMbo is not None:
    childMbo.setValue("MSD_PROJECT", projectId, mbo.NOACCESSCHECK|mbo.NOVALIDATION)
    childSet.save()
    childMbo = childSet.moveNext()
    childSet.close()
    pmSet.close()
    Poonam Gupta
    MSD
  • 2.  RE: Changing attributes on Parent/Child Workorders that are created from PM with route
    Posted 30 days ago
    You should use a crossover domain on the NEWTASKPARENTPMNUM attribute rather than an object save script. IBM covers this here: Special attributes available for crossover domain
    It is set on each WORKORDER during the wogen process and avoids the issue of getting access to the PMNUM from the parent record or getting to the child records.
    Not specific to your question, but you almost never should be saving in a save launch point automation script. Either it's not needed or if it is needed, it means it's part of a separate transaction. A separate transaction can lead to partial commits which can cause all sorts of problems.
  • 3.  RE: Changing attributes on Parent/Child Workorders that are created from PM with route
    Posted 29 days ago
    thanks! That worked. Yes, I am new to maximo and still learning on automation script. I would prohibit from using save function in a script again as suggested by you.
    One more quick question, I also need to copy vendor to parent/child WOs created from PM. What would you suggest for the same?
    Poonam Gupta
    MSD
  • 4.  RE: Changing attributes on Parent/Child Workorders that are created from PM with route
    Posted 25 days ago
    Edited by Steven Shull 25 days ago
    Crossover domain is the best choice whenever possible. If you have multiple fields you can add those fields to the crossover domain. When you need the crossover to be conditional you can even define conditions to only copy over in certain scenarios.
