  • 1.  Ability to configure Sequencing in an ALN Domain
    Posted 02-26-2026 06:09
    Is there's a way to configure the order of the values within an ALN domain? Like adding a Sequence column or something similar?
    The aim is then to display the data in a specific sequence within an external Mobile system.
    Thanks for your help...
    Gilles VIEILLARD
  • 2.  RE: Ability to configure Sequencing in an ALN Domain
    Posted 02-26-2026 15:45
    There isn't a column out of the box and domains are an internal object so you can't add a new column to it in a supported way. And assuming you're talking about something in the classic (IE Application Designer) interface, you can't store this sequence in another table while still utilizing the domain framework for the rest of it. If you need to provide a numeric sequence (not something like sorting alphabetically), you'll need to create a new object in Maximo to store the values & sequence. There's a lot of functionality in the domain framework from caching in the REST API, validation, etc. but it's a relatively simple structure to recreate.
    This would be a good enhancement to the product, and I wasn't able to find an idea out there. It won't help in the near term, but it would be good to submit it here: IBM Sustainability Software - Ideas Portal
  • 3.  RE: Ability to configure Sequencing in an ALN Domain
    Posted 07-01-2026 13:05
    I submitted an idea to IBM.
    IBM Ideas https://ideas.ibm.com/ideas/MASM-I-1894 - Go vote!
    Christi Eades
    City of Fort Worth
  • 4.  RE: Ability to configure Sequencing in an ALN Domain
    Posted 02-27-2026 07:17
    Hi Gilles,
    As mentioned by Steven, there is direct option to achieve sequencing.
    However,
    • If you like to permenantly show values in specific order, you need to add domain values in same order. This way, the 'VALUEID' is configured in required sequence.
    • But you'd like to save in another columns and planning change the sequence, then you need to create new table and pull details via table domain.
    Hope this helps.
    Thanks!
    Sankar Ganesh V S
    DXC Technology
