  • 1.  ad hoc report
    Posted 03-20-2026 00:30
    kindly how create ad hoc report between two dates  for example workorder reported date?
    nasr buzaid
    eni
  • 2.  RE: ad hoc report
    Posted 03-24-2026 08:41
    Hi Nasr,
    One option is to use advanced search to filter the result set to the data you are searching for.  Then create an ad hoc report which will execute on the list retrieved by advanced search.  If this report is to be used frequently the ad hoc report can be modified using BIRT to add start and end date parameters.
    Jim Robb
    GHG Corp.
  • 3.  RE: ad hoc report
    Posted 03-24-2026 09:47
    thank you
    nasr buzaid
    eni
