  • 1.  Adding Attachments to Work Order Requests Coming Through the Email Listener
    Posted 07-27-2023 12:17
    I'm seeking information and guidance on adding attachments to work order requests through the email listener. Is this possible? Can this be configured in Maximo, or is there a commercially available product to achieve this?
    Stevie Holloway
    Tufts University
  • 2.  RE: Adding Attachments to Work Order Requests Coming Through the Email Listener
    Posted 07-28-2023 01:02
    Hi Steve,
    Sorry for being Naive. Could you please elaborate your requirement more?
    I assume you will send an attachment through an email with a wonum embedded in the email, and the attachment should get automatically attached to the WONUM.
    Subhransu Sekhar Sahoo
    PriceWaterHouseCoopers Services Pvt Ltd
  • 3.  RE: Adding Attachments to Work Order Requests Coming Through the Email Listener
    Posted 07-31-2023 08:31
    Yes, something similar to what you described.
    Stevie
    Stevie Holloway
    Tufts University
  • 4.  RE: Adding Attachments to Work Order Requests Coming Through the Email Listener
    Posted 07-31-2023 10:46
    Stevie,
    Similar to a Communication Template and Escalation?  Copied this from Maximo Times,
    The Escalation Setup below is an example of being notified for a Workorder status Change, this will send the Role/Person specified on the Communication Template an email everytime someone changes a WORKORDER to APPR.
    First thing to do is to make sure that you have setup your email settings in the System Properties.   Go ahead and set the mxe.smtp.host setting and the mxe.workflow.admin setting.  You may have to restart the application server for the settings to take effect.
    Create a escalation and fill in the following fields
    Applies to :WORKORDER
    Condition: STATUS='APPR' and STATUSDATE >=(getdate() -1/1440)
    Schedule: 1 minute
    Escalation Point section:
    Elapsed Time Attribute: STATUSDATE
    Escalation Point condition: 1=1
    Check Repeats Box
    Attached a Communication Template to my Notification Section
    Communication Template specifics;
    Applies to : WORKORDER
    Accessible From: ALL
    To: Role you choose
    Send From: Maximo Administrator
    Subject: :WONUM has changed status
    Message: The :WONUM has been changed status to :STATUS on :STATUSDATE
    ****NOTE: Now the REPEATS need to be checked in order for it to notify you on the same Workorder being changed to APPR back to WAPPR back to APPR…..
    The following query STATUSDATE >=(getdate() -1/1440)
    this will check when a STATUSDATE is changed within that last minute…
    Sysdate means it checks the Date on the Server
    -1 means it will check for any changes to the STATUSDATE within the last minute the crontask was running as the schedule is every minute
    1440 is the following calculation
    1440 divided by 60 Seconds ( 1minute)= 24 HOURS
    24 Hours X 60 Seconds= 1440
    So the Crontask runs every minute…but only will send an email when a Workorders STATUSDATE is changed within the last time it ran and the Workorder is changed to APPR…
    Apologize if I'm not even close to what you are asking for.
    Adam
    A.S. Bearden, GDIT
    'ADAM'
