  • 1.  API Calls for External Applications
    Posted 06-08-2023 09:39
      |   view attached
    In MAS 8.8, create an object structure MY_MXWO with object Workorder.
    No child objects etc.
    Database is DB2
    Testing with POST Man works.
    In MAS 8.9 - create same object structure MY_MXWO with object Workorder etc.
    Database is Oracle
    I get the following when I test with Post Man.
    Index 1 out of bounds for Index 1
    Has anyone come across this yet?
    Roger Vallee
    Prometheus Group
  • 2.  RE: API Calls for External Applications
    Posted 06-14-2023 01:37
    Hi Roger,
    Remove the "oslc.select" clause and also the "properties" header and try again. If still it doesn't work, I will suggest you to remove the body element one by one to check what exactly is causing this issue.
    Subhransu Sekhar Sahoo
    Tata Consultancy Services
  • 3.  RE: API Calls for External Applications
    Posted 06-26-2023 08:31
    Hi Subhransu
    The issue was caused by the API key user not having a Maximo default insert site and with further testing the user was missing a labor record.
    Roger
    Roger Vallee
    Prometheus Group
