  • 1.  Attachments on the Desktop Requisition Line
    Posted 01-24-2023 10:02
    A desktop requisition is created, attachments are added at the line level, and then the req is submitted with no issues. When a second desktop req is created, an attachment added to the line, and then saved, the desktop req header reverts to the previous record that was created. This was tested in an environment with no configurations and the same thing happens. Anyone had this issue before?
    Tori Foley
    Cohesive Solutions
  • 2.  RE: Attachments on the Desktop Requisition Line
    Posted 01-24-2023 14:24
    What is the version of Maximo that you are using? I have tested this and couldn't replicate -
    IBM Maximo Asset Management 7.6.1.3 Build 20220823-0909 DB Build V7611-01
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 3.  RE: Attachments on the Desktop Requisition Line
    Posted 01-24-2023 15:53
    This is the version it's happening in:
    IBM Maximo Asset Management 7.6.1.2 Build 20200715-0100 DB Build V7611-01
    Tori Foley
    Cohesive Solutions
  • 4.  RE: Attachments on the Desktop Requisition Line
    Best Answer
    Posted 01-25-2023 09:44
    We had this same issue, which is resolved in IFix 016. See if this sounds like the same problem you are experiencing - IJ34918: PROBLEM DESCRIPTION: 7612 - DESKTOP REQUISITION - AFTER ATTACHING A DOCUMENT ON LINE, HEADER OF THE REQUISITION CHANGED (ibm.com)
    Stephanie Slate
    Insteel Wire Products
  • 5.  RE: Attachments on the Desktop Requisition Line
    Posted 01-25-2023 09:48
    That is exactly it! Thank you!
    Tori Foley
    Cohesive Solutions
