  • 1.  Automation script - Please Help
    Posted 07-25-2024 22:54
    Appreciate any input from you guys:
    I created a new persistent date attribute in ticket object named srdate and i want to populate that field with YEAR only for every transaction in our service request application.
    Can anyone guide me on how to do it?
    Thanks and keep safe everyone.
    Darwin Bagangan
    GNPOWER
  • 2.  RE: Automation script - Please Help
    Posted 07-26-2024 09:07
    Hi @Darwin Bagangan!
    Do you want it to save the year when SR is created, or when SR is modified?
  • 3.  RE: Automation script - Please Help
    Posted 07-28-2024 20:26
    hi @Martin Fabra, thanks for the current year solution. appreciate if you ca nshare also the script for "OTHERYEAR".
    Have a good day ahead.
    Thanks in advance.
    Darwin Bagangan
    GNPOWER
  • 4.  RE: Automation script - Please Help
    Posted 07-26-2024 09:57
    Darwin,
    If you want to save the current year only when you create a new SR, this jython script on SR OBJECT solves it:
    # Script: set_current_year_on_create.py
    # Descripción: Save current year on field "CURR_YEAR" when you create a new SR
    # Get current year
    current_year = Calendar.getInstance().get(Calendar.YEAR)
    # Set the value of the persistent field
    mbo.setValue("CURR_YEAR", current_year)
    Then I will try to pass you the other one, when the SR object is modified.
  • 5.  RE: Automation script - Please Help
    Posted 07-28-2024 20:24
    HI Martin,
    Thanks thanks thanks. This really works for me.
    What Im trying to achieve is to put this script-field on dashboard and use it in result set like in picture below.
    Darwin Bagangan
    GNPOWER
  • 6.  RE: Automation script - Please Help
    Posted 07-29-2024 08:16
    Hi Darwin!
    I'm glad if it worked for you. If you need anything else, let me know and I will be happy to help you.
