Hi Danny,
When you say "I would like to filter those results out by default", can you give us some more context?
I ask because when you disqualify a vendor, they can no longer be used to raise new PR and PO. Nor can they be used as a new vendor on an asset, but can be a manufacturer.
Any approved PO's can continue to be received and invoiced. Interesting fact for rotating items is that even though you cannot add the company as a vendor yourself on the new asset, this process will have the disqualified vendor on the asset. This makes sense as that is where you purchased it.
Of note is that Maximo does not present any warnings or information about any open POs or invoices when you disqualify a company. Again, this makes sense as you have already issued a PO to procure goods from that company before you disqualified them, or for the invoices, you still need to pay for the goods received. Just to be clear, you can still receive items and pay for them....at least in Maximo.
Your company needs to decide if, that as part of the disqualification process, how to deal with open PO's, invoices, preferred suppliers on the reorder tab for items, and there may be more I've missed.
Principal Consultant
COSOL
email:
craig.kokay@cosol.global#IBMChampion
Sent: 04-03-2025 11:30
Subject: Best practices for keeping Companies up to date?
Here's an idea I had to help resolve their issue. Once marked as a "Disqualified Vendor?" then I would like to filter those results out by default so that they only see vendors that have not be disabled.
Where can I set the default query for Companies? Is that in DBCONFIG? For example, in Inventory it automatically excludes Obsolete items when you open the Inventory application.
So it would be something like: (disabled != 1).
Sent: 04-03-2025 10:00
COMPANIES.DISABLED flag should be used for Vendors/Manufactures i.e. companies which no longer to be used. It should never be deleted as it may have historical traces on other transactions records specifically supply chain entities - PR,PO,RECEIPTS etc.
Prashant Bavane
