Best Practices for Maximo Backup & Restore After Namespace Deletion
  • 1.  Best Practices for Maximo Backup & Restore After Namespace Deletion
    Posted 05-27-2025 13:00
    Hi Community,
    I'm looking for guidance on handling a specific disaster recovery scenario for IBM Maximo running on OpenShift-particularly when a namespace (e.g., manage) is accidentally deleted.
    We've tested backup and restore using both OADP (Velero) and IBM Storage Fusion, along with the standard .sh scripts provided by IBM.
    Using OADP:
    • The restore process faced several challenges:
      • Failures in ClusterServiceVersions (CSVs) and Subscriptions
      • Operator instances(especially for Maximo Manage) failed to deploy correctly
    • Even after successful script execution, restoration was only partially successful.
    Using IBM Storage Fusion:
    • Restore was mostly successful, and the Maximo application came back online.
    • However, we encountered an etcd restore error (BMYBR0009) related to a resource group. IBM documentation suggests escalating this to support with logs.
    Despite following IBM's instructions and using the .sh automation scripts:
    • Only basic resources (like Secrets) and the namespace (manage) were restored.
    • Critical OpenShift components such as:
      • Deployments
      • Pods
      • Subscriptions
      • Operators
        were not restored, leading to an incomplete recovery.
    From OpenShift and IBM MAS disaster recovery perspectives:
    • What is the recommended approach to fully recover a deleted namespace that includes both Maximo data and all OpenShift-managed objects?
    • Should we be maintaining a standby disaster recovery cluster, or can this be handled within the same cluster using backup?
    Revanth reddy
