Fulgence, two different errors usually mean two different root causes:
The 401 error (from the pie chart hyperlink) is an authentication issue. When BIRT tries to call a sub-report via hyperlink, it makes a new HTTP request to the Maximo server. If your session cookie isn't being passed along, Maximo rejects it with a 401. Check that your hyperlink URL is using a relative path (not an absolute URL with a different hostname or port) and that your IHS/WebSphere configuration isn't stripping the session on the redirect.
The "Missing required parameter: __report" error means the hyperlink isn't passing the report file path correctly. As Jhonatan mentioned, look at the Hyperlink properties in Eclipse. You need both:
- The
__report parameter pointing to the .rptdesign file path
- The
where parameter with correct syntax, e.g., "yourtable.columnname=" + row["columnvalue"]
A quick way to debug: open the OOTB Work Order Detail report (woprint.rptdesign) in Eclipse and look at how its drill-down hyperlinks are configured - it's the best working reference for getting the parameter syntax right.
Did you get this resolved?
Dusko Delic
Code Development Limited
