  • 1.  Can I freeze Applications' List View headers?
    Posted 07-24-2024 09:11
    Hi Maximo Community,
    Usually the list view displays more records that can be fit on one screen (I noticed that 20 will be the max in a decent size), therefore the need to scroll down, but when you scroll the headers of your result set disappear from your view. Is there a way to freeze them on your view? similar to when you freeze top row in excel.
    I appreciate any tip
    erika mazza
    Region of Durham
  • 2.  RE: Can I freeze Applications' List View headers?
    Posted 07-25-2024 09:23
    You might try this:
    ·  Locate the stylesheet:
    • You need to modify the stylesheet associated with the application. Typically, this can be found in the applications/maximo/maximouiweb/webmodule/webclient/css directory.
    ·  Edit the CSS:
    • Open the stylesheet in a text editor and add the following CSS to create a fixed header for the List tab:
    css
    Copy code
    .fixed-header {
        position: sticky;
        top: 0;
        background-color: #fff; /* Adjust as needed */
        z-index: 1000; /* Ensure it stays on top */
    ·  Apply the class to the header:
    • You need to apply the fixed-header class to the header elements in your List tab. This requires modifying the XML file associated with your application.
    • Locate the XML file in the applications/maximo/properties directory.
    ·  Modify the XML:
    • Open the XML file and find the table headers in the List tab section. Add the fixed-header class to the header elements. For example:
    xml
    Copy code
    <table>
        <thead>
            <tr class="fixed-header">
                <th>Column 1</th>
                <th>Column 2</th>
                <!-- Add other columns as needed -->
            </tr>
        </thead>
        <tbody>
            <!-- Table rows -->
        </tbody>
    </table>
    ·  Deploy and test:
    • Save your changes and deploy the modified files. Clear the cache and reload the application to see the changes.
    Stevie Holloway
    Tufts University
  • 3.  RE: Can I freeze Applications' List View headers?
    Posted 07-26-2024 08:57
    Thank you Stevie!
    I will try it :)
    erika mazza
    Region of Durham
