  • 1.  Can not delete doclinks from MxLoader
    Posted 03-25-2025 06:59
    Hello, everyone,
    I am experiencing an issue when working with attachments in MxLoader, specifically with the delete action.
    I have no issues with other actions such as "Query," "Change," and "Add." I would like to know if the delete action for doclinks in MxLoader is indeed not allowed?
    rio Setiawan Judin
    PT Astra Daihatsu Motor
  • 2.  RE: Can not delete doclinks from MxLoader
    Posted 03-27-2025 01:30
    Hi, yes, you can delete DOCLINKS record. Follow these steps:
    1. Create an Object Structure for the DOCLINKS table.
    2. In the MxLoader sheet:
    • Specify the Object Structure (OS) name.
    • Set the Objectname as DOCLINKS.
    • Choose QUERY as the action.
    • List all primary columns of the DOCLINKS table in the attributes section (e.g., OWNERID, DOCLINKSID, DOCINFOID, OWNERTABLE, DOCUMENT, DOCTYPE).
    • Prepare where clause and Execute the query to retrieve records that have attachments.
          3. Change the action to DELETE and run it. This will delete all records retrieved from the query.
    If you encounter any issue, share it here
    Hariprasad R
