  • 1.  Can the waiting node in the workflow be implemented with automated scripts
    Posted 06-16-2026 22:16
    Hello everyone:
    How to implement custom object's changestatus method or custom object's event method in automated scripts
    Ethan Williams
    secrecy
  • 2.  RE: Can the waiting node in the workflow be implemented with automated scripts
    Posted 06-18-2026 08:43
    Hi Ethan,
    Is the custom object customised with MboStatus handler?
    If so, then you coul dtry the below option?
    Example: maximo.customobjectname.statuschange.appr
    IBM Doc for adding events in Wait node
    https://www.ibm.com/docs/en/control-desk/7.6.1?topic=properties-specifying-wait-nodes
    Steps for implementing StatefulMbo for custom class
    https://maximobase.blogspot.com/2012/10/how-to-change-status-on-custom.html
    Sankar Ganesh V S
    DXC Technology
  • 3.  RE: Can the waiting node in the workflow be implemented with automated scripts
    Posted 06-18-2026 10:56
    Hi Ethan, If you mean to wait untill a specific status occurs on the custom object based record then you can directly check it in the Object launch point before save event. Verify the status using the
    if(mbo.isModified("STATUS") and mbo.getString("STATUS") in['APPR']):
     # write your logic post that
    Prashant
    Prashant Dixit
    ACCENTURE
