Can we restrict User to see/edit any field in message reprocessing XML
  • 1.  Can we restrict User to see/edit any field in message reprocessing XML
    Posted 04-09-2024 10:10
    Hi Team,
    Can we restrict User to see/edit any field in message reprocessing XML.
    Example: Suppose we got error like (BMXAA4195E - A value is required for the Asset field on the ASSET object.). If user have to change Asset field data then User should only able to access Asset field.
    Please let me know, is there any way to do this customization.
    Lakhan
    #Security
    Lakhankumar Makadia
    Tata Consultancy Services
  • 2.  RE: Can we restrict User to see/edit any field in message reprocessing XML
    Posted 04-09-2024 16:25
    Hi  @Lakhankumar Makadia !  I don't know if I understand correctly.
    You mean when you try to exit a record without recording, and then Maximo presents indicating that some data is missing.
    There are many times that in the system, we make fields mandatory and those fields have null values.
    When we navigate through those registers, if it is read-only for a user, the error will arise that will not allow us to advance until registering the missing value and we cannot because we do not have permission. That's what you mean?
