  • 1.  Can you add data to a custom field using MX Loader?
    Posted 10-14-2023 13:00
    Field:   Manufacturer Date
    Table.Column:   ASSET.TM_MANUFACTUREDATE
    Manufacturer Date
    Is it possible to load data to a custom field using MX Loader?  It hasn't worked for me so far.
  • 2.  RE: Can you add data to a custom field using MX Loader?
    Posted 10-14-2023 22:43
    Assuming the attribute / field was added as persistent, it should work. The object structure would get updated by the database configuration action that added it in the first place. MXLoader however may be out of synch, so you may need to go to the MxLoader tab in Excel and 'Refresh Data Dictionary' or just use the wizard and create a new sheet.
  • 3.  RE: Can you add data to a custom field using MX Loader?
    Posted 10-17-2023 17:43
    Thank you @Christopher Winston.  Everything was up to date as far as I know.  It seems that once I created a new sheet and focused on those fields it worked fine.
