Cannot download doclinks attachment using the MxLoader 8.5
  • 1.  Cannot download doclinks attachment using the MxLoader 8.5
    Posted yesterday
    Hello Pros,
    I am running into an issue trying to download the doclinks attachment for an Item using the latest MxLoader. Has anyone used the MxLoader 8.5 version to download doclinks attachment?
    We duplicated the OOTB OS and then removed other child objects and added DOCLINKS object to it and joined it with a relationship. Below is the output for the query that I am running using MxLoader for an item.
    ITEMNUM    1156092
    ITEMSETID    ITPostEM1
    DOCLINKS.DOCUMENT    TEST
    DOCLINKS.DOCTYPE    Attachments
    DOCLINKS.DOCINFOID    508499
    DOCLINKS.URLTYPE    FILE
    DOCLINKS.URLNAME    E:\doclinks\attachments\test.pdf
    DOCLINKS.DESCRIPTION    test.pdf
    FileEnc:DOCLINKS.DOCUMENTDATA FileEnc:/./Itemattachment/E:\doclinks\attachments\test.pdf
    It returns all the information in the sheet, but the file is not getting downloaded even though it does create an Itemattachment and E folder under Itemattachment folder in the folder where the MxLoader file is saved.
    When I try to use FileEnc:DOCLINKS.URLNAME, the folder Doclinks created and the attribute remains blank (ie. no value is returned) for query.
    I am not sure what am I doing wrong here, so I need some guidance on resolving this issue. Thank you very much in advance for your help.
    Vandna Patel
    G
