  • 1.  Characteristic Measurements Not Visible in Asset After Inspection Form Completion
    Posted 02-03-2025 06:43
    Hello everyone,
    I created an inspection form in a work order, added a measurement group to the asset, and filled out the form. After completion, I checked the asset's measurement history, but only GAUGE measurements (numeric values) appeared. Characteristic measurements (predefined values from a domain list) were missing.
    Checking the ASSETMETER table, I found that LASTREADING is empty for characteristic meters. However, the values exist in INSPFIELDRESULT.
    Why aren't characteristic measurements updating in ASSETMETER? Is there a missing configuration, or should I use a different approach to make these values visible in the UI?
    Any help is appreciated!
    Matis Dovydas
  • 2.  RE: Characteristic Measurements Not Visible in Asset After Inspection Form Completion
    Posted 02-07-2025 23:38
    Hi Matis,
    Readings for characteristic meters are typically not carried over automatically, as they represent static attributes.
    Readings for gauge and continuous meters can be carried over to the asset or location meters. You may want to try creating automation script and associate with Form so completion can push these entries to respective Characteristic meter.
    IBM Champion 2022|2023|2024|2025
    Lets learn MAS @ https://www.youtube.com/@reliabilityodyssey/
  • 3.  RE: Characteristic Measurements Not Visible in Asset After Inspection Form Completion
    Posted 02-10-2025 08:00
    Thank you for your response! I understand that characteristic meter readings aren't carried over automatically.
    I also noticed that on a PC, inspection forms can be viewed in either Web View or Mobile View, with Web View being the default. Could you advise how to enable Mobile View on a PC? Is this set up in the security group or elsewhere?
    Additionally, in Web View, I can't see characteristic measurements with domain values (predefined choices). Could this be due to a configuration issue, or is it a limitation of Web View?
    I appreciate your help!
    Matis Dovydas
