Copies a Custom attribute from MXUSER object to the newly created ITEM record using CROSSOVER Domain
  • 1.  Copies a Custom attribute from MXUSER object to the newly created ITEM record using CROSSOVER Domain
    Posted 11-26-2025 09:04
    Hello Maximo Experts,
    I am trying to copy a custom field from the MAXUSER object of the logged in user to the ITEM record using a crossover domain, so when he creates the record the value of this field is populated automatically from the MAXUSER object. Is it possible to do that, or it is recommended to use an automation script instead ?  Thank you!
    Oumayma Azouz
    AtkinsRealis
  • 2.  RE: Copies a Custom attribute from MXUSER object to the newly created ITEM record using CROSSOVER Domain
    Posted 11-28-2025 06:02
    Probably look at using an automation script to action this
    Niv Geo
