  • 1.  Create Requisition not editable in Application Designer
    Posted 10-13-2025 18:05
    Hello all,  I was attempting to add a field to show data from Assets in CREATEDR but it was not possible.  Is this application not able to be edited?
    Thank you in advance,
    #Procurement
  • 2.  RE: Create Requisition not editable in Application Designer
    Posted 10-13-2025 19:48
    So I've learned a little more about this, but still unsure about how/where and if it's possible to add fields from the MRLINE table to the CREATEDR application.
  • 3.  RE: Create Requisition not editable in Application Designer
    Posted 10-14-2025 04:02
    Edited by Tinnokesh AP 10-14-2025 04:05
    Hi Danny,
    Greetings !!
    This particular section definition of CREATEDR application will be in library.xml. You would be able to perform the field inclusion via library.xml for this particular scenario.
    Thanks & Regards,
    Tinnokesh AP
