  • 1.  Create XML Import to Enterprise Services
    Posted 03-08-2023 09:28
    I would like to ask for help on what is the process of creating an XML file then import it afterwards in Enterprise Services Application. Thank you!
    #Analytics
    #Architecture
    #CivilInfrastructure
    #HSE/OilandGas
    #Infrastructure
    #IoT
    #LifeScience/Calibration
    #Linear
    #MaximoForAviation
    #Nuclear
    #Procurement
    #Scheduling
    #Security
    #ServiceProvider
    #Spatial
    #Transportation
    #Utilities
    #WorkCenters
    Eugenio Cabalhin
    IBM Solutions Delivery Inc
  • 2.  RE: Create XML Import to Enterprise Services
    Posted 03-08-2023 09:53
    Am I doing it correctly?
    Eugenio Cabalhin
  • 3.  RE: Create XML Import to Enterprise Services
    Posted 03-09-2023 08:42
    That error message implies a data issue rather than a syntax issue.  It looks like you're importing data for a closed WO, SR, or other object that does not allow changes to closed records.
    The easiest way to create an XML file for Import is to first do an Export for a similar record through a Publish Channel for the same Object Structure and then add the "action=" to the main object tag and make any necessary changes to data values.
    Julio Hernandez
    Ergonare, Inc.
  • 4.  RE: Create XML Import to Enterprise Services
    Posted 03-13-2023 17:32
    Hi Julio, this works fine, Thank you so much for your help! :D
    Eugenio Cabalhin
