Hi Julio, this works fine, Thank you so much for your help! :D
Eugenio Cabalhin
IBM Solutions Delivery Inc
Sent: 03-09-2023 08:42
Subject: Create XML Import to Enterprise Services
That error message implies a data issue rather than a syntax issue. It looks like you're importing data for a closed WO, SR, or other object that does not allow changes to closed records.
The easiest way to create an XML file for Import is to first do an Export for a similar record through a Publish Channel for the same Object Structure and then add the "action=" to the main object tag and make any necessary changes to data values.
Julio Hernandez
Ergonare, Inc.
Sent: 03-08-2023 09:53
Am I doing it correctly?
Eugenio Cabalhin
