  • 1.  Custom Application Workflow
    Posted 07-08-2025 10:56
    We created a custom application and want to use workflow with it. However, it's not listed when we select object when creating the new workflow. Did we miss a setting in the database object or application design? Or is workflow not available for custom apps?
    Jason Johnson
    RSI
  • 2.  RE: Custom Application Workflow
    Best Answer
    Posted 07-09-2025 08:30
    Edited by Jason Johnson 07-10-2025 06:26
    Hey Jason,
    Is your custom application using a custom user-defined Object? If so, is this a Main object in DB Config?
    It'll need to be set as such in order to configure a Workflow against it.
    Let us know your outcome.
    Cheers,
    Matt
    Matt F
  • 3.  RE: Custom Application Workflow
    Posted 07-10-2025 06:26
    That was it, thank you!
    Jason Johnson
    RSI
