  • 1.  Customization of Date Format in IBM Mobile App
    Posted 04-30-2025 11:07
    Hello Maximo Open Forum,
    I have a question regarding the IBM Mobile customization for reading date formats. When starting and stopping a timer, the Labor Approval screen is displayed, showing both the date/time and duration. On our tablets, the native app currently displays the time with AM/PM at the bottom of the time field. We would like to modify it so that the AM/PM is displayed on the same line as the time, horizontally.
    Could you please guide me to where in the code the date/time format is controlled?
    Note, even when we turn the tablet in landscape, AM/PM is displayed under the time.
    Thank you in advance for your help!
    MARK FRITZ
    GM
  • 2.  RE: Customization of Date Format in IBM Mobile App
    Posted 05-15-2025 15:45
    I have been trying to recreate the issue, but I have been struggling. I have tried to mimic different resolutions in developer tools and resizing the windows, but it seems that any time I cross the threshold it puts it into the small width which causes it to expand to 100% of the space and prevents the issue. I'm pasting what it is out of the box in case the sizing has changed in your environment.
    the large-width is likely the column size when you are in landscape. In the example below the column is 50%. If you don't have it as 50 & 50 I would change it to that. But if you do, you could try to change it to 60 & 40 for example and see if that makes a difference.
                  <top id="bx268">
                    <adaptive-row id="kd7ew">
                      <adaptive-column large-width="50" medium-width="50" small-width="100" small-horizontal-align="start" medium-horizontal-align="start" large-horizontal-align="start" id="pxjp5">
                        <box id="w9ww9">
                          <box direction="row" horizontal-align="start" fill-parent="true" id="qpqjr">
                            <field label="Start date and time" id="w_ge5">
                              <sub-field value="{woLaborDetaildsOnSchedule.item.startdate}" type="date_full_month" id="jaq36"/>
                            </field>
                            <label label="at" hidden="{!woLaborDetaildsOnSchedule.item.starttime}"  id="m_4e6"/>
                            <field hidden="{!woLaborDetaildsOnSchedule.item.starttime}" id="w5xg8">
                              <sub-field value="{woLaborDetaildsOnSchedule.item.starttime}" type="time" id="mq_d3"/>
                            </field>
                          </box>
                        </box>
                      </adaptive-column>
                      <adaptive-column large-width="50" medium-width="50" small-width="100" small-horizontal-align="start" medium-horizontal-align="start" large-horizontal-align="start" id="v5gyv">
                        <field label="Duration" id="ngq86">
                          <sub-field value="{woLaborDetaildsOnSchedule.item.regularhrs}" type="duration_long" id="ye7w7"/>
                        </field>
                      </adaptive-column>
                    </adaptive-row>
                  </top>
  • 3.  RE: Customization of Date Format in IBM Mobile App
    Posted 05-19-2025 08:26
    Thanks Steven,
    I will test these changes out,
    Mark
                              GM Mobility / MAS Mobile Share point: Mobility Share Point Site
