Dashboard result set incorrect chart values
  • 1.  Dashboard result set incorrect chart values
    Posted 03-19-2024 09:04
    I've created a dashboard with some KPI's and a result set.
    The KPI's are working correct.
    I have an issue with the result set.
    With the result set I want to show how many App points are used per day.
    The list is working correct.
    There are only 4 colomns in the table and using 2 in the result set.
    When I click on chart view based on the date I only see the value 1 multiple times.
    When I select the other colomn I see a count based on the value of that colomn but I don't want that.
    How can I change this (without affecting other result sets) so that I can see the date with the correct value in the chart?
    Overview App Points used per day
    App Point chart overview
    Jim Scholten
    Gemba
