  • 1.  DELETE ASSETS FROM JOB PLAN
    Posted 10-19-2023 19:31
    Hello all, I was wondering if you could delete Assets from a Job Plan.
    I tried using the sheet I used to add Assets to a Job Plan, but it was trying to delete the actual Job Plan instead of only removing the assets.
    Thank you
  • 2.  RE: DELETE ASSETS FROM JOB PLAN
    Posted 10-20-2023 09:03
    Have you tried putting ~NULL~ in the asset field in the JP template and running it as a change?
    glenda creech
    G-Force Consultants
  • 3.  RE: DELETE ASSETS FROM JOB PLAN
    Posted 10-20-2023 09:08
    Hi Danny,
    Glenda is correct.
    To add some background, you're deleting the entire job plan because what ever action is selected in cell C1 is actioning against the object in cell B1. The same applies to if you wanted to delete a child record like a job plan task. You'd have to create a new object structure where the parent object is JOBTASK, and then run a delete.
    Matt McGuire
    Aquitas Solutions
