  • 1.  Difference between Red Asterisk and Black Asterisk in IBM MAS
    Posted 03-31-2026 16:45
    Hello everyone, I have a question from our Maximo community where they are asking what the difference between a red asterisk and a black asterisk in IBM Maximo Application Suite (MAS). I've come across these terms often but haven't been able to find a clear explanation or the specific use cases for each. If anyone has insights or knowledge about this topic, I would greatly appreciate your help! Thank you in advance for your assistance. Best regards, John Bauer
  • 2.  RE: Difference between Red Asterisk and Black Asterisk in IBM MAS
    Posted 03-31-2026 22:58
    Hi John,
    I have not tested this theory myself, nor have I run into a Black Asterisk that I can think of, but I did some research. I found that a Red Asterisk is a hard system requirement. Think something like a WONUM when creating a new WO. This is a required field. Always required, no matter the situation. While a Black Asterisk may become required. Something like a conditional UI rule, or a needed field based on a status, etc.
    I hope this helps you.
    Allan Henle
  • 3.  RE: Difference between Red Asterisk and Black Asterisk in IBM MAS
    Posted 04-01-2026 15:21
    Thanks for you info Allan, we have found the below explaination which I think answers my question
    Fields can be set as being compulsory at a database level. Those with a red asterix indicate those fields that have been set at this level. When a field is set at a database level however, it is required from the moment a record is created prior to saving.
    Those fields with a black asterix have had the label changed and the asterix added, as a means of visually identifying other fields that are compulsory, but not on saving of the record. In work orders, the fields are compulsory at different stages in workflow, which is why we can't set them at a database level.
    Cheers
    JB
    John Bauer
    Mercury
