  • 1.  Does Maximo 9.1.15 Contain Bugs?
    Posted 06-11-2026 00:46
    Upon decompiling the class, it is observed that the dataBean parameter passed into the DataBeanContext constructor has not been initialized.
    Ethan Williams
    secrecy
  • 2.  RE: Does Maximo 9.1.15 Contain Bugs?
    Posted 06-11-2026 08:44
    Looking at your screenshot it does appear that the constructor accepts the databean parameter but it then doesn't use it.
    This would need to be raised with IBM as a support case. They will need a log demonstrating the NullPointerException that is raised when the getDataBean() method is called.
    mark robbins
    Cohesive
  • 3.  RE: Does Maximo 9.1.15 Contain Bugs?
    Posted 06-11-2026 08:46
    This has been this way since it was implemented. I'll be honest, I haven't opened a support ticket to get a defect on it. IBM never documented this feature publicly. I only learned of it because I was at IBM and did this presentation (MSUG - Automation Scripts in Maximo Application Suite | Maximo Open Forum) to share to a wider audience. Since then, people covered it even further including my now colleague Andrzej (https://www.linkedin.com/pulse/ibm-mas-manage-ui-bean-scripting-andrzej-wieclaw-4vtbf/ )
    Undocumented features are a little bit trickier to get defects approved because it has never been documented how you are supposed to be able to utilize it. But in this scenario, I imagine if someone opened the support ticket, they would get IBM to approve it.
