I am using the Maximo REST API to update compatible unit (CU) estimates (CUs are part of the Maximo T&D industry solution). I am using the SYNC method to update existing CU estimates, using the primary key values in the JSON message body. For example, here is the message body of a message that successfully updates the descriptions on the CU estimate header, the estimate version and the station:
"requestnum": "1007",
"description": "HDS_CUESTIMATE2 update test 2024-09-21-1",
"orgid": "EAGLENA",
"plusdestversion": [
"estversion": 1,
"description": "Design estimate version update 2024-09-21-1",
"plusdstation": [
"estversion": 1,
"description": "Design station 1 2024-09-21-1",
"stationkey": 1,
"station": "1",
"siteid": "BEDFORD",
"plusdstndetail": [
"estversion": 1,
"quantity": 20.0,
"stndetailkey": 1,
"cuseq": 1,
"cuname": "TESTCU2",
"expandflag": false,
"workfunction": "I",
"cuversion": 1,
"parameterset": 0,
"station": "1",
"plusdstndetailid": 302
"siteid": "BEDFORD"
I now need to add a new CU item to an the existing station. Here is the JSON message:
"estversion": 1,
"plusdstation": [
"stationkey": 1,
"plusdstndetail": [
"_action": "Add",
"parameterset": "0",
"station": "1",
"cuname": "TESTCU3",
"status": "ACTIVE",
"quantity": "5.0"
This API call generates a 400 error. Here is the output in SystemOut.log:
[9/21/24 14:24:35:275 EDT] 00000163 SystemOut O 21 Sep 2024 14:24:35:275 [ERROR] [MXServerc1] [CID-MXOSLC-4477] BMXAA6714E - The data for the next record in the mboset could not be retrieved for the SQL query select * from plusdcu where and cuname = 'TESTCU3' and cuversion = 1 OPTION (FAST 1000) . See the log file for more details about the error.
com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near the keyword 'and'.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:265) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1676) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteCursored(SQLServerStatement.java:2074) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:881) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement$StmtExecCmd.doExecute(SQLServerStatement.java:802) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7730) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:3786) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:268) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:242) ~[sqljdbc.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeQuery(SQLServerStatement.java:724) ~[sqljdbc.jar:?]
at psdi.mbo.MboSet.getNextRecordData(MboSet.java:3375) [businessobjects.jar:?]
at psdi.mbo.MboSet.fetchMbosActual(MboSet.java:2983) [businessobjects.jar:?]
at psdi.mbo.MboSet.fetchMbos(MboSet.java:2940) [businessobjects.jar:?]
at psdi.mbo.MboSet.getMbo(MboSet.java:2130) [businessobjects.jar:?]
at psdi.mbo.MboSet.isEmpty(MboSet.java:4455) [businessobjects.jar:?]
at psdi.plusd.app.plusdcuest.PlusDFldStationDetailCUVersion.validateCuVerStatus(PlusDFldStationDetailCUVersion.java:226) [businessobjects.jar:?]
at psdi.plusd.app.plusdcuest.PlusDFldStationDetailCUVersion.validate(PlusDFldStationDetailCUVersion.java:76) [businessobjects.jar:?]
at psdi.mbo.MboValue.validate(MboValue.java:1757) [businessobjects.jar:?]
at psdi.mbo.MboValue.setValue(MboValue.java:939) [businessobjects.jar:?]
at psdi.mbo.MboValue._setValue(MboValue.java:1153) [businessobjects.jar:?]
at psdi.mbo.MboValue.setValue(MboValue.java:1138) [businessobjects.jar:?]
at psdi.mbo.Mbo.setValue(Mbo.java:2733) [businessobjects.jar:?]
at psdi.plusd.app.plusdcuest.PlusDFldStationDetailCUName.action(PlusDFldStationDetailCUName.java:254) [businessobjects.jar:?]
at psdi.mbo.MboValue.validate(MboValue.java:1783) [businessobjects.jar:?]
at psdi.mbo.MboValue.validate(MboValue.java:1660) [businessobjects.jar:?]
at psdi.mbo.Mbo.validateAttributes(Mbo.java:5148) [businessobjects.jar:?]
at psdi.mbo.Mbo.validate(Mbo.java:4686) [businessobjects.jar:?]
at psdi.iface.mos.MosProcessImpl.checkValidateErrors(MosProcessImpl.java:2443) [businessobjects.jar:?]
at psdi.iface.mos.MosProcessImpl.setAdditionalTableData(MosProcessImpl.java:1761) [businessobjects.jar:?]
at psdi.iface.mos.MosProcessImpl.createChildrens(MosProcessImpl.java:990) [businessobjects.jar:?]
at psdi.iface.mos.MosProcessImpl.createChildrens(MosProcessImpl.java:1002) [businessobjects.jar:?]
at psdi.iface.mos.MosProcessImpl.fillMaximoTables(MosProcessImpl.java:827) [businessobjects.jar:?]
at psdi.iface.mos.MosProcessImpl.processExternalData(MosProcessImpl.java:360) [businessobjects.jar:?]
at psdi.iface.mos.MosProcessImpl.processObjectStructureService(MosProcessImpl.java:255) [businessobjects.jar:?]
at psdi.iface.mic.MicService.processObjectStructureData(MicService.java:934) [businessobjects.jar:?]
at psdi.iface.mic.MicService.processOSLCAsJSON(MicService.java:638) [businessobjects.jar:?]
at com.ibm.tivoli.maximo.oslc.provider.OSPOSTRouteHandler.handleRequest(OSPOSTRouteHandler.java:914) [businessobjects.jar:?]
at com.ibm.tivoli.maximo.oslc.provider.MaximoOslcProviderServlet.handleRoute(MaximoOslcProviderServlet.java:1300) [commonweb.jar:?]
at com.ibm.tivoli.maximo.oslc.provider.MaximoOslcProviderServlet.processPostPut(MaximoOslcProviderServlet.java:1412) [commonweb.jar:?]
at com.ibm.tivoli.maximo.oslc.provider.MaximoOslcProviderServlet.doPost(MaximoOslcProviderServlet.java:266) [commonweb.jar:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:595) [javax.j2ee.servlet.jar:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668) [javax.j2ee.servlet.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1233) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:782) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:481) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget(WebAppFilterChain.java:136) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:97) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.tivoli.maximo.filter.UnSupportedMethodBlockFilter.doFilter(UnSupportedMethodBlockFilter.java:60) [commonweb.jar:?]
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:195) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:91) [com.ibm.ws.webcontainer.jar:?]
at psdi.webclient.system.filter.HttpXFrameOptionsFilter.doFilter(HttpXFrameOptionsFilter.java:38) [classes/:?]
at psdi.webclient.system.filter.MTContextFilter.doFilter(MTContextFilter.java:53) [classes/:?]
at org.apache.logging.log4j.web.Log4jServletFilter.doFilter(Log4jServletFilter.java:71) [log4j-web-2.17.1.jar:2.17.1]
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:967) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1107) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:87) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:952) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:213) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.ready(HttpInboundLink.java:287) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.sendToDiscriminators(NewConnectionInitialReadCallback.java:214) [?:CCX.CF [o2228.02]]
at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.complete(NewConnectionInitialReadCallback.java:113) [?:CCX.CF [o2228.02]]
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892) [com.ibm.ws.runtime.jar:?]
It looks like the generated SELECT query is missing a criteria before the "AND". What is causing this error? Am I not setting one or more attributes correctly in the message?
-Theo Pozzy
#Integrations------------------------------
Theo Pozzy
OneGas
