  • 1.  Error For Publishing TECHMOBILE
    Posted 11-22-2023 10:23
    Receiving below error at the time of publishing TECHMOBILE xml
    Anyone can suggest where I can check the logs
    Souvik Dutta
    TCS
  • 2.  RE: Error For Publishing TECHMOBILE
    Posted 01-17-2024 16:59
    Hi Souvik,
    Have you been able to find a solution to this?
    Nathan Tabenkin
    Starboard Consulting
  • 3.  RE: Error For Publishing TECHMOBILE
    Posted 01-21-2024 18:57
    You can check the container logs on your Docker Desktop. If you see a similar message below, it means your container tried to use more memory than you have available. Try restarting your PC and stopping other apps.
    INFO: server/29 on 5cd454d91e2d: received a get request to get application TECHMOBILE status (req_id=2b680fef-8457-46bf-a068-a4e17ecd7454)
    The build failed because the process exited too early. This probably means the system ran out of memory or someone called `kill -9` on the process.
    [2024-01-21T23:29:59.381Z] ERROR: server/29 on 5cd454d91e2d: 1
    [2024-01-21T23:29:59.387Z] ERROR: server/29 on 5cd454d91e2d: 1 (req_id=2b680fef-8457-46bf-a068-a4e17ecd7454)
    Maycon Belfort
    BPD Zenith
