  • 1.  Error while updating Maximo records using REST API and Postman
    Posted 02-06-2026 11:20
    Hi all,
    I have been trying to test the Maximo REST API for updating records and received this following error:
     "BMXAA1496E - The WORKORDER record does not exist in the database and cannot be updated or deleted.",
    Even though the work order exists in the database, I tried using WORKORDERID as well and got the same result. I also tried adding the WORKORDERID in the URL, but I still get the same error.
    Using Object Structure: MXWO
    I am not sure where I am doing wrong and any help would be appreciated.
    Thanks!
    Raziela Avdylaj
    InfoSoft Business Solutions
  • 2.  RE: Error while updating Maximo records using REST API and Postman
    Posted 02-06-2026 14:31
    What header you are using?
    x-method-override should be SYNC, deselect the patch type as MERGE and try again
    Subhransu Sekhar Sahoo
    PriceWaterHouseCoopers Services Pvt Ltd
  • 3.  RE: Error while updating Maximo records using REST API and Postman
    Posted 02-09-2026 04:58
    Hi Subhransu,
    Thank you for your help. I deselected the patchtype = MERGE as you guided; used "PATCH" for x-method-override and also used the workorderid in the URL.
    Now the records are updated successfully.
    Thanks again!
    Raziela Avdylaj
